4l80e to np205 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2009, 03:01 PM   #1
billywilly92
billywilly92's Avatar
Default 4l80e to np205
I have researched this for hours but have not found one definite answer. Since you guys know so much on here I figured someone would know the answer or would have actually done it.
I want to put an np205 behind a 4l80e. I need to know what np205 to get, what 4l80e to get, and what adapters and stuff I would need to connect the two.
Anyone know about this or have done this before?
billywilly92 is offline   Reply With Quote
Old September 9th, 2009, 09:19 PM   #2
atvextreme
atvextreme's Avatar
what do you have right now? the reason i ask is there is a short answer and a long one to this.
if you have a turbo 400 and a figure 8 , 32 spline 205 set atm, its easy with some machine work on the adapter.
if your going to go out and piece meal this together it will get quite expensive.
It sounds like you are looking at the same decisions i was when i gave up and settled on a 700r4 / 241 combo.
as for mating the trans and t-case, advanced adapters sells a kit for 600.00 and tells you which parts you need.
atvextreme is offline   Reply With Quote
Old September 9th, 2009, 10:16 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I mated that combo 5 years ago...take measurements but I remember cutting around an inch of the output shaft of the 4l80e other than that it has been many moons ago
Old September 10th, 2009, 02:12 PM   #4
billywilly92
I don't have either yet. I was just wondering how easy this is to do and which parts I should get. I wish I could just find a 91 crew cab that had this combo from the factory. I might just go a different route until I can save up enough for this combo.
I read that there are 3 different 4l80e transmissions out there. There is a long output, a short output, and an rv output. The rv one you have to cut done and maybe the long one to but I am not sure. I just don't want to go out buying parts and then not be able to use them together.
Old September 15th, 2009, 04:26 PM   #5
TanTahoe
TanTahoe's Avatar
I dont believe the 4L80E's came out till 93? I could be wrong, but i thought that the 80e and 60e's came out around the same time.
IMO, it would be easyer to get a 4L80E and a NP241 Tcase. You would need a NP241 from a GM 90-91 SUV and a tcase input shaft from a 4L80E trans.
I havent looked at a 80E out of a truck, but how does the computer read the speed signal if you get ride of the sensor in the 241?
TanTahoe is offline   Reply With Quote
Old September 15th, 2009, 07:25 PM   #6
KILLER"B"468
Yankabilly
I do know that they came as a mated pair 4l80e/np205 in the 91 v3500 crewcabs. I am still looking to see where I have put my old chicken scratch of the pair.
Old September 17th, 2009, 04:51 PM   #7
billywilly92
There is a way to match the two up. A bunch of people do it its just that they aren't very clear in stating how they did it, they just say they did. I think it might just be easier to find a manual and hook it up to the 205. It seems like a 80 and 205 would be way to much money to connect.
Yeah I wish I could find a factory setup but those are expensive and hard to find.
Old September 17th, 2009, 08:12 PM   #8
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
What spline NP205 do you have first?
http://advanceadapters.com/index.php...on_24=GM+4L80E
Old September 19th, 2009, 05:07 PM   #9
billywilly92
I don't have one i was just looking into it and to see if there was a way to do it that was cheaper than buy the adapter from advanced adapters.
Page generated in 0.42543 seconds with 50 queries
