10,500lb Winch w/Synthetic Rope - $599.99 - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 9th, 2009, 02:43 PM   #1
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Default 10,500lb Winch w/Synthetic Rope - $599.99
Performance 10,500lb Winch w/ Synthetic Rope
Lightweight. Durable. Tough. Affordable. The Performance 10,500lb Winch from Rugged Ridge is everything you could want in a competition winch. It is driven by a durable 6.6 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 218:1 gear ratio delivers power and reliability on each and every pull. The Performance 10,500lb Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge synthetic rope style Winches include hawse fairleads. Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Performance 10,500lb Winch Features/Specifications
  • Durable 6.6 HP Series Wound motor for long life and extra pulling power
  • Tough 3 stage planetary gear box with a 218:1 gear ratio delivering power and reliability
  • Automatic load holding brake system (in the drum brake system)
  • Tough stainless hardware is used on the body of the winch to eliminate rust
  • 3/8" x 94' of Synthetic Rope constructed of Dyneema SK-75 fiber with a breaking force of 19,310lbs!
  • Significantly stronger than same diameter steel cable and up to 40% stronger than Kevlar
  • 1/7 the weight of the same diameter wire rope
  • Will not splinter, kink, or curl like wire rope & floats in water
  • Specially coated to be resistant to UV, abrasions, and chemical solvents
  • Each winch includes a durable 12’ all-weather cable remote solenoid box that can be mounted in multiple positions (over roller or over motor) and angles to accommodate most winch bumpers including the Rugged Ridge® XHD Bumper System!
  • Limited 2 year warranty against manufacturing defects (1 year on electrical)
http://jeeperz-creeperz.com/product_...ucts_id=107376
Also available in 8,500lb version for $499.99 - http://jeeperz-creeperz.com/product_...ucts_id=107375
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old October 1st, 2009, 04:57 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
October Bump!
Thanks for the orders!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Thread Tools
Page generated in 0.24119 seconds with 29 queries
