12 gauge steel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2009, 08:28 PM   #1
cglenn
Default 12 gauge steel
Would it be good to use 12 gauge steel to make lower door armor on a Jeep XJ? I wouldn't care about scratches, I just want it to be moderately dent-proof. I have a 24x48 sheet of it with nothing to use it on. I was going to make tube flares but I no longer have access to the tools I need.
I figure if it could work it would work good. It would keep the weight of the doors down a bit instead of bulletproofing it with 3/16 or 1/4" steel (overkill for my application I think). I'd drill holes rosette style to weld the plate to as well. This would just be the lower probably 6 inches of the doors, right up to the first crease where the plastic door scratches are. Thanks.
cglenn is offline   Reply With Quote
Old September 8th, 2009, 09:59 PM   #2
Tab
Tab's Avatar
Thats almost 1/8th so it would be better than the stock sheetmetal. If you already have it I say go for it.
Old September 8th, 2009, 10:57 PM   #3
cglenn
I just want to make sure it would be worth doing. I don't want to replate it. Granted this isn't an area that has a high chance of denting but still. I'd like to do it right the first time, and if this is good enough I'll do it.
Old September 8th, 2009, 11:02 PM   #4
MiNi Beast
MiNi Beast's Avatar
just do it.
Page generated in 0.22301 seconds with 35 queries
