Electric garage heater - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2009, 11:00 AM   #1
1stREALjeep
Flight or Fright?
1stREALjeep's Avatar
Default Electric garage heater
This would make a great heater for a 2 car garage. Made by Q-Mark, runs on 208v, single or 3 phase. I dont know a whole lot about it, but specs can be found here: Qmark Type MUH Unit Heater then scroll down to catalog# "MUH078". This is not a cheap heater. Its a few years old, but has very little use. Comes with mounting bracket and timer controller. Timer can be set in small increments up to 6 hours or put on hold, or you could just wire it direct to an on/off switch. Will not seperate from timer. $275.
If interested, please email D1802 (at) sbcglobal (dot) net I have a few things listed on various sites and my little single track mind has a hard time keeping track of who asked what and on what site.
1stREALjeep is offline   Reply With Quote
Old September 8th, 2009, 02:54 PM   #2
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Just so that everyone understands, (and no im not being a dick), this is a 208 volt heater and is not dual rated for 240v as some of the others are. You would need a buck boost transformer to make this work at home.
Old September 8th, 2009, 02:58 PM   #3
1stREALjeep
Flight or Fright?
Im glad you brought this up. I dont know much about home electrical, so would this be compatible with the "220" commonly found in residential?
Old September 8th, 2009, 03:01 PM   #4
BigBlkYJ 355
U-Joints Fear Me
No, the 220 you speak of is actually 240 volts. 208 volt is a 3 phase WYE voltage, not found in homes.
Old September 8th, 2009, 03:17 PM   #5
1stREALjeep
Flight or Fright?
Interesting. The spec tag on the heater says 1/3 phase and so does the spec list on the site I linked.
Old September 8th, 2009, 03:25 PM   #6
BigBlkYJ 355
U-Joints Fear Me
correct, it will work on either 3 phase or single phase 208 volt. Not single phase or 3 phase 240v
Page generated in 0.18821 seconds with 41 queries
