solid axel on 99 expedition - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2009, 11:36 AM   #21
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Most dana 44s use the 1310 style U-joint. Do you know what you had on the the pumpkin of the old IFS axle? It could have even been a CV style I'm not sure. But you will either need a new drive shaft, an adaper or you may be able to get yours changed to match.
brandonjb is offline   Reply With Quote
Old September 8th, 2009, 05:04 PM   #22
prozak1986
prozak1986's Avatar
my stock front axels are cv , not sure what my front shaft is thow ( i know its tiny and is flat on the ends and uses 4 12mm 12point bolts on both ends ) , it does take u joints in it thow because i just replaced them about a month ago , thats all i realy know about it
prozak1986 is offline   Reply With Quote
Old September 8th, 2009, 05:37 PM   #23
brandonjb
YJ enthusiast
brandonjb's Avatar
Sounds like a 1310 they have small ass bolts that hold the covers on over the u-joint caps. Your dana 44 will have little u-bolts instead, they hold up better. You may end having your drive shaft shortened (assuming the u-bolt style is the same) or if it's too short you may need a new one.
Old September 8th, 2009, 09:46 PM   #24
prozak1986
prozak1986's Avatar
my front drive shaft is a slip style and i can get a good 3-4inches of movement from it so as long as it bolts up i guess i should be ok
Old September 8th, 2009, 11:56 PM   #25
PavementPounder
PavementPounder's Avatar
Not a good vehicle to bother doing anything to.
Old September 9th, 2009, 12:20 AM   #26
brandonjb
YJ enthusiast
brandonjb's Avatar
PP has spoken, take it to the nearest junk yard lol.
I think he means there are better trucks to start with that would be a lot less work to get the same result.
Old September 9th, 2009, 02:08 AM   #27
N8sBroncoMI
Boones Farmer
N8sBroncoMI's Avatar
why not use ford 78/79 radius arms? easy to set up
N8sBroncoMI is offline   Reply With Quote
Old September 9th, 2009, 09:54 PM   #28
Offroadexpy
Rockin' the Stocker'
Offroadexpy's Avatar
Actually TTB might not be a bad choice for an expedition.
Weld in the Pivot member and the radius arm member.
Whats your complaint about the torsion bars?
Offroadexpy is offline   Reply With Quote
Old September 9th, 2009, 10:12 PM   #29
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
i wouldn't put A ttb on ANYTHING!
garbage
Old September 9th, 2009, 10:16 PM   #30
Offroadexpy
Whats wrong with TTB?
Not saying its as good as a solid axle, but waaay more flexy then Torsion bars.
Old September 9th, 2009, 10:42 PM   #31
prozak1986
prozak1986's Avatar
not saying anythings wrong with the torsion bars , just tired of the weak ass front ifs
Old September 10th, 2009, 01:14 AM   #32
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Send a message via Yahoo to Chrisholmz
Do you really plan on wheelin a full size expidition? Thats a lot of truck. The IFS is probably just as strong as a 77-79 D44 so that would be a poor reason to swap it. I bought a complete balljoint, controller arm, and tie rod end kit for my 97 f150 off ebay for around $165 shipped to my door. It only takes around 4 to 5 hours to swap everything plus an alignment. In the end, you know it will work.
Just curious since a TTB swap came up. Has anyone ever seen a vehicle without TTB seen TTB swapped in it?
Chrisholmz is offline   Reply With Quote
Old September 10th, 2009, 10:52 AM   #33
prozak1986
prozak1986's Avatar
yes i do plan on wheelin a expedition lol , there not that big of a truck , i know people who wheel excursions
Old September 10th, 2009, 04:23 PM   #34
04PSD
aka Langford
04PSD's Avatar
a guy I know put a SFA on his 97 F-150 (same setup as the expedition), he used everything from a 99-04 F-250/350. D60 front on leaf springs, and he recently swapped a cummins in place of the 4.6 liter.
His name is Jesse and goes by bigreen on pirate4x4, fordtruckworld, and a few other forums. He owns farmboy fabrications, and is a really good guy....I'm sure he would be able to help answer any questions and give you a few tips to make it go easier.
04PSD is offline   Reply With Quote
Old September 10th, 2009, 04:41 PM   #35
brandonjb
YJ enthusiast
brandonjb's Avatar
I agree, Expedition is the same width as a full size ford truck plus it's a little shorter. Also It's the same width as a full size Bronco or Blazer. What's the big deal?
Old September 11th, 2009, 12:01 PM   #36
Chrisholmz
ESTRADA
Chrisholmz's Avatar
This link is of a Tahoe build with leafs. The guy who built it uses the forum all the time and may give some better insight on setting it up.
Ton(s) of fun Tahoe - Midwestern 4x4 Forums
Are expiditions coil spring in the rear? If so, I would consider changing it to leaf springs. IMO leafs in a vehicle like that would increase the stability quite a bit for sidehills and hill climbs. I doubt the flex of coil springs would be worth it since rock crawling and tight trails would not be the best type of wheelin for an expidition.
If you do the build, take pics and make a thread. There's not nearly enough 97+ ford 1/2 ton build-ups on the net to get information from.
Old September 11th, 2009, 12:55 PM   #37
prozak1986
prozak1986's Avatar
yes expeditions are a coil spring in the rear , i think im doing to stick with the springs in the rear for now untill they give me a reason to swap them out , thanks for the help guys
Old September 11th, 2009, 11:03 PM   #38
Offroadexpy
It would be awesome to see another Expedition out there playing.
I had a blast with mine down at bundy hill this past weekend, and its all stock.
Honestly, the Torsion bar IFS isnt ALL that bad, hell, my buddy got 3 ft of air with his 2000 F150 and landed it, just fine.
The coil sprung rear isnt all that bad either, and leaf spring setup from an F150 would be kinda rough to do because the frames are different in the back (the expedition is actually considerably taller).
Hell with it, put on a lift, some bigger tires, and go play. As soon as i get some money im puting a 3inch and 33's on mine.
Page generated in 0.44957 seconds with 78 queries
