88 1500 4x4 not engaging - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2009, 08:32 PM   #1
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Default 88 1500 4x4 not engaging
my buddy has an 89 chevy 1500 w/t, 5.7L 350, 400 trubo trans, np 241 trans case
like the title says, the 4x4 is not working, when you pull the shifter back into 4hi the case engages, and the front driveshaft wont turn by itself (like it would if it was in 4x2). so it's gotta be an electrictal problem, the actuator is good because it's brand new, it's the electric style actuator not the heat activated one
there is some fluid in the front diff, it's not full but it's not empty either
any thoughts?
Old September 4th, 2009, 08:42 PM   #2
jmw55018
Oh poop
jmw55018's Avatar
start checking electrical connections. i had an 88 and the plugins corrored off up over the t-case. i just wired the front end actuator up with a toggle switch and bypassed all the other stuff. it also allowed me to run in low range without the front end locked in if i wanted.
jmw55018 is offline   Reply With Quote
Old September 4th, 2009, 09:06 PM   #3
wave_crusher
I'll Direc your TV
so we could just wire the actuator directly to power, and use a toggle switch like you did? i wasn't sure if you could wire it right to a power source
Old September 4th, 2009, 09:12 PM   #4
jmw55018
Oh poop
jmw55018's Avatar
it worked for me and it was kind of a half ass fix. i might look into adding a fuse or relay into the system versus just direct wireing it. you dont want a fire under the dash or melting shorted wires. i ran mine for a long time direct wired but it didnt really bother me as the truck was a pos.
Old September 4th, 2009, 09:28 PM   #5
wave_crusher
I'll Direc your TV
got some good info from chevy_4x4_trucks, it looks like it might be the washer between the halfshaft and diff, we'll/he'll have to take a look at that
Old September 5th, 2009, 12:36 AM   #6
boggin-machine
boggin-machine's Avatar
x2 on the hard wire. ive seen it done alot. that also means that you can run the rear end in 2lo for what ever reason you see needed. but it will work.
Page generated in 0.14859 seconds with 41 queries
