1994 F350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2009, 05:30 PM   #1
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
Default 1994 F350
the front head lights wont work change both bulbs and the light switch and still no lights, if i pull back on the high beam handle and hold it the lights will work. any thoughts would help ive tried everything
roger is offline   Reply With Quote
Old September 5th, 2009, 12:30 AM   #2
Yota Bill
you havent tried everything, but you did answer your own question
Old September 13th, 2009, 11:09 PM   #3
roger
roger's Avatar
so are you telling me its the high beam switch
Old September 13th, 2009, 11:29 PM   #4
jmw55018
Oh poop
jmw55018's Avatar
thats where i would be headed
jmw55018 is offline   Reply With Quote
Old September 14th, 2009, 12:14 AM   #5
Yota Bill
thats called a multi function switch, and yes, that is most likely the problem
Old September 16th, 2009, 09:47 PM   #6
roger
roger's Avatar
thanks i will work on that next
Old September 16th, 2009, 10:48 PM   #7
Yota Bill
these sometimes have a problem with the lube that is in them, though I cant remember what problems it caused (seems like it was more of a wiper issure then any of the lights)
look at the end of the switch and you will see that it is a plastic cap, pry that cap off, then remove the one screw inside, being careful not to let the end fly off, it is spring loaded...remove and clean, relube with a small amount of dielctric grease, reassemble
Old November 19th, 2009, 07:48 PM   #8
roger
roger's Avatar
okay i changed the multi function switch and no head lights still im going crazy i cant figure this out
Old November 20th, 2009, 12:14 AM   #9
Yota Bill
OK, so, to recap, you have replaced the multi-function switch, the headlight switch, and both headlamps, and you still have a problem of the high beams only working in the "flash-to-pass" position, correct?
looking at the schematic, the multi-function switch is the only component I see that could cause this problem...
does this have a tilt wheel? is there any excessive free play or movement in the steering column itself? any signs of damage to the column or the wiring or connectors in that area?
Old November 20th, 2009, 12:45 AM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
I live in Mid-China. Bring it to me and I will get it going for a modest fee.
Old November 20th, 2009, 08:00 AM   #11
roger
roger's Avatar
yes to all
yes it haves a tilt wheel i looked at the wirers and i cant find any damage
Old November 20th, 2009, 06:38 PM   #12
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Follow the power and repair/replace whatever it is that doesn't have it.
Start by checking power TO the headlight switch and work your way to the headlights.
IIRC, the flash-to-pass and the low beam circuits are fed by separate fuses.
Old November 20th, 2009, 08:43 PM   #13
roger
roger's Avatar
im going to try that tomorrow
Old November 21st, 2009, 12:09 AM   #14
Yota Bill
does this have daytime running lamps?
Old November 21st, 2009, 09:17 AM   #15
roger
roger's Avatar
nope
Old November 21st, 2009, 11:08 PM   #16
Yota Bill
then I would say the problem has to be either in the multi-function switch or the wiring/ connectors in and around the steering column, which could have been damaged from movement in the column, or during a repair.
Old November 22nd, 2009, 06:20 PM   #17
roger
roger's Avatar
ok i work on it for 3 hours sat when i pull the headlight switch no power to the lights but i jump the head light wirer at the switch and the lights worked the i think i bought a bad head light switch so im going to take my son in law switch out of his truck that i know works and put it in mine
Page generated in 0.28467 seconds with 74 queries
