Ford Tranny woes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2006, 08:06 PM   #1
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Question Ford Tranny woes
...need help, I have an E04d in my F150, and for some reason in low range it will not shift through the gears. I can manually shift 1st to second, but when I shift to Drive it goes right back to first.
The wierd thing is that it works fine in high range............any suggestions?
Old June 27th, 2006, 08:28 PM   #2
FORD FLARESIDE
bump,...........does anybody know Fords, Or do I need to sell it and buy a Jeep?
Old June 27th, 2006, 09:02 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I will check the books. It may be a faulty EPC in high range it has enough umf to switch the gears. But when in low and it calls for it quicker the solenoid may not be able to keep up with the quick upshifts.
Old June 27th, 2006, 09:12 PM   #4
FORD FLARESIDE
That makes sense.......................
I probably should have mentioned that I put about 3 grand into this tranny about 10,000 miles ago. It does have a shift kit and lock up torque covertor now. (if they could be part of the problem)
Supposedly the solenoid pack was replaced last year, but I cant verify it because I did not get the old one back from the transmission shop.
I will get the meter out tomorrow and start checking things.
Old June 28th, 2006, 09:43 AM   #5
Bones
Bones's Avatar
wow, for $3000 you should have bought a box from http://www.brianstruckshop.com/
Only thing I can think of it low line pressures through the VB.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 28th, 2006, 09:57 AM   #6
FORD FLARESIDE
.....the cost was in the Planetary gears. I didn't put the aluminum ones back in. I paid extra and put the steel ones in with the 6 outer gears vs. 3 outer gears stock. I didn't want to have to mess with the tranny again, go figure..........
Old June 28th, 2006, 09:29 PM   #7
FORD FLARESIDE
I took the Flareside across the gravel pit today in Low Range, seems to shift through all the gears now. All I did was unplug the wiring harness at the tranny, spray some cleaner in it, and plug it back in.
Could just corrosion on the terminals cause this situation?
If this is the case, I think I'm going to shrink-rap all of my connections.
Old June 28th, 2006, 09:46 PM   #8
KILLER"B"468
Yankabilly
Yes, pull it back off and put di-electric grease in ther and make sure it snaps together when plugged in.
Old June 29th, 2006, 08:42 AM   #9
FORD FLARESIDE
....Thanks for all the help, y'all are great.
Page generated in 0.32664 seconds with 50 queries
