86 ranger ext cab 4x4 $500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2006, 06:12 PM   #1
The Wonder Monkey
Shock The Monkey
The Wonder Monkey's Avatar
Send a message via AIM to The Wonder Monkey Send a message via Yahoo to The Wonder Monkey
Default 86 ranger ext cab 4x4 $500
needs some work. i know the timing needs reset and the fuel pressure regulator leaks. haven't gotten much past that. want it outta my garage. $500 and come and get it. thanks.
The Wonder Monkey is offline   Reply With Quote
Old June 27th, 2006, 06:14 PM   #2
Ebs
What engine/trans? Mileage?
Old June 27th, 2006, 06:25 PM   #3
The Wonder Monkey
Shock The Monkey
sorry, guess that would've been helpful. its the 2.9 v6 and i'm assuming the stock 5 sp manual trans. a previous owner told me the 2.9 was a crate with probably around 20,000 on it. i don't know how to tell and i have no receipts to prove it though. odometer reads 51,xxx i believe which i'm also assuming has turned over.
Old June 27th, 2006, 11:45 PM   #4
blacy001
blacy001's Avatar
does it run
blacy001 is offline   Reply With Quote
Old June 28th, 2006, 12:43 AM   #5
The Wonder Monkey
Shock The Monkey
i'm not very mechanically inclined, so i never even tried to get it to run but i had a neighbor down the street come check it out for me (who is a mechanic at a local shop) and he got it to fire up in 5 minutes. he said the timing needs to be reset, he only adjusted it and it started right up. he's also the one that said the fuel pressure regulator is leaking. the timing will need adjusted again or reset to fire up though.
Old June 28th, 2006, 07:16 AM   #6
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I'm assuming it's located in NW Ohio somewheres?
Old June 28th, 2006, 10:56 AM   #7
The Wonder Monkey
Shock The Monkey
just outside of toledo. sorry.
Old June 28th, 2006, 05:54 PM   #8
heath_36
$200 dollar paint job
heath_36's Avatar
Got any more pics? mjheath@mtu.edu please.
heath_36 is offline   Reply With Quote
Old July 19th, 2006, 04:52 PM   #9
The Wonder Monkey
Shock The Monkey
Old July 19th, 2006, 07:44 PM   #10
bumpy
jeep>volkswagen
bumpy's Avatar
if i could sell my comanche id buy it..
bumpy is offline   Reply With Quote
Old July 20th, 2006, 12:44 AM   #11
The Wonder Monkey
Shock The Monkey
thats cool, homes. there were a couple of guys checkin one out over on gotmud.
Old August 19th, 2006, 11:12 PM   #12
The Wonder Monkey
Shock The Monkey
how about $300 ? ? ? and the odometer reads 115,xxx
Old August 21st, 2006, 05:31 PM   #13
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
do you still have this if the timing and pressure regulator were fixed would this be ddable? what do you think I need something cheap to get by on for the winter. lmk I would possibly like to come look this weekend
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old August 21st, 2006, 09:14 PM   #14
The Wonder Monkey
Shock The Monkey
i don't think it would take a whole lot more than that. i would put better tires on it cos the 31's aren't in real good shape. that and there is no exhaust from where the cat converter should be. other than that, i don't see why it wouldn't get you through the winter. but that would be up for you to decide. just let me know if you wanna come check it out. we can probably work something out for this weekend.
Page generated in 0.32377 seconds with 65 queries
