My first build YJ...*Update* - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2009, 03:22 AM   #41
Erock33
Erock33's Avatar
Well lately I just have been picking up some odds and ends U bolts & plates, made a set of shock mounts for the axles just have to find tune them. Made some simple brackets to mount the explorer rear disc brake hoses to the spring perch.
Also I have talked with Alcan spring really not bad on price for custom tailored leafs I had originally had RE 1.5" leafs $160 in budget and the Alcan with a 0" lift leaf is $210 so I have saved money in the past by making odds and ends so WTF why not...
Also just cause I want to see how strong this NP231J is when modified I installed a 6 gear planetary out of a NP231C, I am going to try and find wide chain gears in the junk yard buy a new chain and install a JB Conversions supper short SYE and see what happens if it breaks looks like a Atlas II is going in...
I am on the home stretch finally once JB Conversions gets a shipment in I will have that SYE then set some drive line angles. Decided to go with Tom Woods for drive shaft no local shop gave me the price I wanted to hear TW ~290 to my front door
Erock33 is offline   Reply With Quote
Old November 8th, 2009, 08:12 PM   #42
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Send a message via AIM to Xj Wheeler
this is simply amazing..very talented.
Xj Wheeler is offline   Reply With Quote
Old November 8th, 2009, 08:41 PM   #43
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Looks Good
CHEVYRCKS is offline   Reply With Quote
Old November 10th, 2009, 09:47 PM   #44
Erock33
Erock33's Avatar
I picked up 2 6 pack leafs and installed then in the rear with poly bushings I am going to do the same for the front and I have JB conversions super short SYE on order
Old November 17th, 2009, 12:30 AM   #45
Erock33
Erock33's Avatar
Today I spent most of the day hooking up new loaded calipers to the front and ran extended brake hoses also plumed the rear end with brake line then bleed the brakes
Also got the JB conversions super short SYE today installed that and measured for my rear drive shaft will be ordering that soon
Old November 17th, 2009, 01:26 AM   #46
boggin-machine
boggin-machine's Avatar
looks good man. it will be done just in time for winter. wheeling in winter is great!!
Old November 17th, 2009, 04:31 AM   #47
Erock33
Erock33's Avatar
I haven't been wheeling since 2004 somewhere out in PA, it will be nice just to have it back on the road was thinking about a new years day run but that's not happening now
Old November 21st, 2009, 03:47 AM   #48
Erock33
Erock33's Avatar
I started to make a new xcase shifter it is just about done. Ordered a pulley and bracket kit for the motor for a saginaw power steering pump I also am in the middle of making my exhaust decided to go with 2 1/4" to a Y then go 3" all the way back with a Magnaflow muffler should sound just right I hope
Old November 22nd, 2009, 11:42 PM   #49
Erock33
Erock33's Avatar
After last week when I bleed the brakes I did notice that the pedal went to the floor after bleeding due to the add 3/4 ton brakes, so I picked up a 78 Mercury grand marquis master cylinder with 4 wheel disc for 16 bucks at the local parts store bench bleed it but didn't rebleed the brakes yet but I got a good pedal now
Also measured for my driveshaft got some good length out of that JB SYE and putting motor as far forward as possible 24 3/4″.
Also ordered a new clutch master cylinder and slave cylinder with hose
Old December 4th, 2009, 12:42 AM   #50
Erock33
Erock33's Avatar
Well I have just received my Tom Woods drive shaft today so that will be going in tomorrow
I have been making some progress on my exhaust I have it all the way up to the muffler waiting on more bends to come in here is my only picture of this. Its 2 1/4" pipe to 3" with a Magnaflow 3" muffler
So hopefully everything goes good and I am able to burn everything in on the axles then I just have to get my clutch slave and master cylinder going
Old December 5th, 2009, 11:39 AM   #51
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
The YJ looks great!
Old December 5th, 2009, 12:12 PM   #52
T_MAN
T_MAN's Avatar
i hope my yj will turn out half as good as yours. good build
T_MAN is offline   Reply With Quote
Old December 5th, 2009, 04:44 PM   #53
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Send a message via Yahoo to lizzardboy
Holly molly, that is one of the best builds i have seen! Great job man.
lizzardboy is offline   Reply With Quote
Old December 7th, 2009, 10:53 PM   #54
Erock33
Erock33's Avatar
Here is a clip of my exhaust
Also got leaf perches welded onto axles this week got my clutch figured out and took it around the block tonight holy hell this thing is nuts
Old December 11th, 2009, 03:44 AM   #55
Erock33
Erock33's Avatar
well the other day I got bored and decided to try out that VHT header paint on some of the exhaust, I am going to use some exhaust wrap too the pipe going under oil pan is pretty close so I hope that using that will prevent the exhaust from heating up the oil.
As far as my clutch hydraulic setup went, I used a 92 F150 7/8's bore master along with the matching 7/8's bore slave. Had to make a bracket to offset the master about a 1" to the drivers side to get enough room to clear the brake booster, also had to move the master about a 1" off the firewall to keep the pedals lined up and still get a full stroke to the floor boards.
I need to find some fittings for the master and slave, right now all I have done is take the stock fittings weld a brake line fitting on the end used a union and then made a steel brake line to connect them together
I will get some pictures up hopefully someone might know what I am looking for
Old December 27th, 2009, 07:53 AM   #56
VanTheMan
VanTheMan's Avatar
That's an inspiring build, man! I wish I had half your skill!
VanTheMan is offline   Reply With Quote
Old December 27th, 2009, 08:07 AM   #57
93XJcountry
Nothing Runs Like a Deere
93XJcountry's Avatar
that is a damn nice yj, good job on the build
93XJcountry is offline   Reply With Quote
Old February 6th, 2010, 09:52 PM   #58
Erock33
Erock33's Avatar
I have been up to a lot lately but no pics uploaded will be working on that possibly tomorrow, I did put a under drive pulley kit on w/ 3G 130A alternator converted my manual steer to power steering exhaust finally made it all the way to the rear of the Jeep replaced the front springs w/ 6 leaf springs I ended up getting them gauge pod to replace the factory gauges
My next projects are to finish plumbing the fuel lines make a anti wrap bar for the rear axle and add a few gauges and get a steer shock hooked up
Old March 1st, 2010, 07:10 PM   #59
Erock33
Erock33's Avatar
I just got new gauges installed this past weekend, I have my front ring and pinion install kit on the way and the correct fittings to plumb my fuel system
Old March 1st, 2010, 09:53 PM   #60
drew91xj
drew91xj's Avatar
looks good have always liked the yj's might be my next build
Page generated in 0.59382 seconds with 84 queries
