Wanted: Someone with an acetylene torch and some spare time. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2009, 05:30 PM   #1
Chief Brody
Get off my lawn.
Chief Brody's Avatar
Default Wanted: Someone with an acetylene torch and some spare time.
Well, I officially decided today that I am a fucking idiot. I managed to break BOTH the bolts that hold the gearbox in place to the frame. I have a new gearbox sitting on the garage floor that wants to be put in, but unless I duct tape it in place, it isn't going anywhere.
So, I'm looking for someone that wants to lend a hand. I figured the best route is the heat the shit out of them and try to get them out with some vice grips or something. Problem is my choices are limited to a lighter or a shitty propane torch.
If you have an acetylene torch, some spare time, and a short drive to my house let me know! Or if you know someone nearby that could lend a hand... I'm in Kalamazoo. If a meet and greet sounds better so a bunch of people can join and work on their shit, that would be cool too!
Pictures of my retardedness.
Chief Brody is offline   Reply With Quote
Old September 1st, 2009, 07:15 PM   #2
jsmtam90
Old School Jeeper Club
jsmtam90's Avatar
that suck's...however fixable, if you can't find someone with a torch let me know, I will show you how I replaced the bolts/nuts on my 86 Cj7.
jsmtam90 is offline   Reply With Quote
Old September 1st, 2009, 08:21 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
thought about mapp gas on your torch head instead? it might work. it gets quite a bit hotter than propane. worth a shot i guess?
Old September 1st, 2009, 08:57 PM   #4
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
are those threaded into the frame???
if so try this:
get 2 nuts, preferably a couple jam nuts, they are thinner and lock a little better.
After letting bolts soak in PB plaster for couple hours put both nuts on remaining threads..tighten them on each other good an tight...now try to loosen the nut closest to frame. The bottom nut will hold the top nut in place and you will either
A) get it out
B) break it again
if you do "B" then get yourself the proper drill bit (I would use at least 1/32 less than the tap drill for that size bolt personally) and drill it out. Getting the drill bit centered correctly is the tricky part, start with a smaller bit to get a pilot hole and go from there. You should be able to determine how off center you are and establish how big hole you can make before you start going into the threads.
just a thought.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old September 1st, 2009, 09:44 PM   #5
Chief Brody
Get off my lawn.
I was going to pick up some from work tomorrow. I'm doubting it will work though... they are in there REAL fucking good.
if so try this:
I'll give the jam nuts a try. I was trying it today with regular nuts but I don't really have much room to play with them...... lol
Old September 1st, 2009, 09:49 PM   #6
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
I'd grind a flat spot on either side to get a real tight grip with vise grips, and some patience tapping the grips with a hammer, in both directions to break them loose.
MISHOWJEEPER is offline   Reply With Quote
Old September 1st, 2009, 10:05 PM   #7
rob4407
rob4407's Avatar
cant you just drill them out?
rob4407 is offline   Reply With Quote
Old September 2nd, 2009, 12:41 PM   #8
Chief Brody
Get off my lawn.
That's my last resort. The bolt threads into the frame so if I fukc up those threads I'll be really pissed.
Old September 2nd, 2009, 12:41 PM   #9
Chief Brody
Get off my lawn.
I'll try that.
Old September 2nd, 2009, 12:45 PM   #10
Pokerob
hug life
Pokerob's Avatar
yea those bolts break (almost) everytime without heat.
Your not an idiot its just your first time dealing with them.
get those hot and vise grip them out.
i also recommend doing the other side (since you will have the torches) and the skid plate......replace those bolts you wont regret it .
Old September 2nd, 2009, 01:30 PM   #11
dmcjeep
dmcjeep's Avatar
Very good advice
dmcjeep is offline   Reply With Quote
Old September 9th, 2009, 08:26 PM   #12
Chief Brody
Get off my lawn.
So, I was out dicking around in the garage tonight and took a hammer to the bottom of them...... they popped right out lol.
The nut looked like it had a tiny bead on it to keep it in place.
Page generated in 0.47872 seconds with 59 queries
