Low-mile Nissan SD-33 I6 diesel from a CJ-10a flightline tug. 34080 miles and 5823 hrs. Tug was fully functional and ran beautifully prior to part-out. Very complete, including 23-spline TF-727 transmission (will accept NP-pattern cases like D300, 208J, 231, 241, etc). Already has the Scout SD-33 oil pan to clear a Dana 300. Original pan included if you prefer to run a driver-drop transfer case/high-pinion front axle, as well as a very nice and well-built set of frame mounts to fit 76-up CJ frames that were very carefully sliced off the frame they were built onto (pics below). Also included is the documentation on the tug.
This is the driveline from the tug that 1x1_Speed_Craig parted out and the mounts he built for the CJ-8 he installed it in. I have both the original CJ-10a frame from that same tug and a non-rotted CJ-7 frame available to set this into.
Both the driveline and frame have been stored indoors since I acquired them. My plan was to build a "CJ Brute" with the frame (no outboarding required for full-size axles and way beefier than a FSJ frame) and driveline, an Aqualu half-cab and pickup bed, a CJ front clip, a CJ-8 or GR8TOPS half-cab hardtop, and adding the rear half of a Wagoneer frame to get the required frame length to support the pickup bed. With all the other vehicles and projects I have, it would be forever before I could undertake this project. So, I'm moving it along.
On sale for $1200 for a limited time! Frame is extra. No dibs. First-come, first-served based on payment. Cash, PayPal, or USPS Money Order. No checks or other types of money orders.
I can palletize and ship at your cost. I will also haul it a reasonable distance for a fee. This would include into neighboring states, such as Ohio, Indiana, and into the Chicagoland area. Bringing it into Ontario would be difficult. If you are in Canada, it will be simpler for you to come get it.
Sold.
Sold.
