Bending Corner Guards - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 31st, 2009, 12:40 PM   #1
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
Arrow Bending Corner Guards
I am looking at making some of the corner guards like the ones below. My question is, how would you come about making the bend around the rear corner. I was thinking about bolting it on the back and then heating and bending as see fit. Just wondering if anyone has any other ideas. It will be 3/16" thick steel. TIA!
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old August 31st, 2009, 01:23 PM   #2
I don't know what kind of pricing you get on material but I went the Barbedwireoffroad.com route(whiskeyv8 on ebay). $157 to the door for corner blanks pre bent.
Heres a similar thread:
Jeep fender cut and corner protection - OFN Forums
Old August 31st, 2009, 04:12 PM   #3
Yota Bill
go get 2 pieces of pipe that are a few inches longer then the piece you want to bend, with a radius that matches the radius you want to bend it at, weld a piece of heavy flat stock between each end of the 2 pipes so that they are parallel and about 1/2-3/4 inch apart....you will then need to make some sort of a stand to hold it, which could just be made out of some scraps (I would make the stand so that the piece you are bending is getting pushed down)...you could also weld a piece of flat stock to one of the pipes so you can clamp the material and keep it straight, but thats not entirely necassary...insert material, heat, and bend
if that doenst make any sense, I cna draw a quick pic of what I'm talking about
trying to heat and bend 3/16 around your sheetmetal will just cause alot of damage to what you are trying to protect
Old August 31st, 2009, 04:30 PM   #4
forbyefore
forbyefore's Avatar
yota bill's jig idea is how I would do it too. You would mess your corners up for sure. The heat and metal scuffing it up can't be good
forbyefore is offline   Reply With Quote
Old August 31st, 2009, 09:59 PM   #5
brimy311
Smells like a Fork Liftis
brimy311's Avatar
You won't be able to bend 3/16" steel without alot of heat or without a press. You could probably get away bending 1/8" though.
JcrOffroad.com
Like us on Faceook!
Old August 31st, 2009, 11:06 PM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
With that much material (24" or so?) you would need the whole bend cherry to bend it by hand. We looked into getting the tooling to bend 1/4's in our press and it's $$$
JcrOffroad
Zoom Zoom!
Old September 1st, 2009, 09:30 AM   #7
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
1/4" corner guards? where the f do people take their jeep? Iraq?
Mulely is offline   Reply With Quote
Old September 1st, 2009, 09:48 AM   #8
3/16 material x 24" in length will take approximately 90 tons (180,000 pounds) to bend without heating. Yield strenghts stay pretty constant up till around 1100 degrees F.
So, good luck.
Old September 1st, 2009, 11:21 AM   #9
LuckyCharm4x4
Thanks guys for killing all of my dreams, haha.
Whiterhino - how about 18" of 1/8" is that still pretty impossible?
~Bry
Old September 1st, 2009, 11:27 AM   #10
kj kyle
kj kyle's Avatar
you definatly need corner guards for sand
kj kyle is offline   Reply With Quote
Old September 1st, 2009, 11:39 AM   #11
You do if an IED is under the sand
Old September 1st, 2009, 11:39 AM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
So, good luck.
The chart for our press says .188 is 7.5 tons per foot with a 2" bottom die, 14 tons per foot with a 1" bottom die.
Still more than your going to do by hand.
JcrOffroad
Zoom Zoom!
Old September 1st, 2009, 11:58 AM   #13
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Well I have a possible work around if your good with a welder and a grinder... Buy some tubing the that was the same radius as the corner you are trying to protect. Then cut it in quaters length wise. Use these quaters as your corners and weld your flat each side. Grind down the welds and your done. A lot of work but it could work.
brandonjb is offline   Reply With Quote
Old September 1st, 2009, 12:09 PM   #14
LuckyCharm4x4
I was thinking that too, but a 6-8" tube could be expensive. It's kinda janky too!
~Bry
Old September 1st, 2009, 12:14 PM   #15
brandonjb
YJ enthusiast
brandonjb's Avatar
If you do a really good job lining everything up, and finishing your seems no one would ever know lol. True big tubing like that would be pricey, you would have to weigh it against the cost of buying pre-built ones.
Old September 1st, 2009, 03:10 PM   #16
95geo
newbie
95geo's Avatar
www.speedymetals.com for the tube
and why waste your time when such an affordable product like the one from barbed wire offroad exists?
Old September 1st, 2009, 03:31 PM   #17
LuckyCharm4x4
I contacted barbed wire and they said they took them off their online store due to not being able to have free shipping any more. I'm waiting to get a quote from them to see the new shipping/product rates.
~Bry
Old September 1st, 2009, 04:02 PM   #18
Glad I got them when I did.
Old September 1st, 2009, 04:20 PM   #19
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
my local lazer cutter will layout/cut/bend custom ones for around $250 and that is 100&#37; custom. after all the layout is done he can do them for $150 a set.
Old September 1st, 2009, 04:32 PM   #20
Pokerob
hug life
Pokerob's Avatar
Originally Posted by chadcooper55 View Post
my local lazer cutter will layout/cut/bend custom ones for around $250 and that is 100% custom. after all the layout is done he can do them for $150 a set.
sucks for the 1st person who want set
Page generated in 0.51539 seconds with 84 queries
