1972 Honda AZ 600 upgrade. - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Should I make a rat rod out of my turd Honda or fix it up.
Rat Rods are what cool, and besides, everything Nuggets owns looks like a rat rod. 41 38.68%
For the love of God, put some effort into this project and fix it up. 46 43.40%
I'm a closed minded a-hole who will make nasty comments because I'm jealous. 19 17.92%
Voters: 106. You may not vote on this poll
Old April 2nd, 2010, 10:55 AM   #161
bigdogwaggy
bigdogwaggy's Avatar
thing is wild, very cool.. and i thought the bbc in a citation that a buddy is building was small
bigdogwaggy is offline   Reply With Quote
Old April 25th, 2010, 06:42 PM   #162
L4CX
Out for the Summer!
L4CX's Avatar
Any new updates? I am Anxious to see what this is going to look like.
L4CX is offline   Reply With Quote
Old April 25th, 2010, 11:05 PM   #163
Nuggets
I fix stuff!
Nuggets's Avatar
I am really burned out for working on cars right now. For some reason I just can't spend more than a few hours at a time at my shop. I've been putting all my effort into remodeling the second story of my house (a 8 year project to this point).
I'm starting to feel the spark of interest in the project again so I will be posting some updates soon. My next task is to fab up motor and tranny mounts so I can set everything in and find out the ride it of the chassis.
Old May 13th, 2010, 06:19 PM   #164
Nuggets
I fix stuff!
Nuggets's Avatar
Here is my secret to stuffing a SBC in the middle of a (formerly) 2 banger Honda. The shortyglide.
This is just a mock up for now. I still have to put the shorty planetary in and convert the valve body to work without the governor.
Old May 13th, 2010, 06:21 PM   #165
Nuggets
I fix stuff!
Nuggets's Avatar
Mock up of engine and trans in frame. Engine is just dangling above frame at this point. I started on motor mounts last night but I fucked up the angles so I have to start over. I will be sitting almost on top of the rear axle in case you were wondering.
Old May 16th, 2010, 11:17 AM   #166
Nuggets
I fix stuff!
Nuggets's Avatar
I got the motor mounts welded in place. Next stop, tranny mount.
Old May 16th, 2010, 04:29 PM   #167
Blazin_wheeler
turtles like me
Blazin_wheeler's Avatar
wow that is crazy.
Blazin_wheeler is offline   Reply With Quote
Old July 12th, 2010, 08:42 AM   #168
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Any more pics? This is going to be the craziest go kart ever
Old July 12th, 2010, 10:38 AM   #169
Nuggets
I fix stuff!
Nuggets's Avatar
I haven't been working on it much lately. I'll be getting back to it soon.
Old July 12th, 2010, 12:54 PM   #170
JimNut
JimNut's Avatar
One of the craziest build threads I have seen. That is going to be one wild ride when you get it completed!
JimNut is offline   Reply With Quote
Old August 22nd, 2010, 01:49 AM   #171
Nuggets
I fix stuff!
Nuggets's Avatar
Ok, I dusted the Honda off and started to tinker with it again. I now have the motor and transmission all bolted into the frame. I had a tough time figuring out how to make a transmission mount because when you make a shortyglide, you loose the trans mount. What I eventually came up with was a ring I made on the lathe that would bolt up to the back of the trans on top of the shortyglide plate. I then welded a tab on the bottom of the ring for a trans mount. From this point it was easy, just a few mounting tabs on the frame, some holes drilled (and slotted) and there it is: a functional transmission mount with factory style rubber isolator.
He look, my fancy drill press can make slots too.
Psycho trans mount. The slot in the tab is so I can access a bolt. The slot is a little on the sloppy side because I cut it with the plasma cutter freehand. I'll clean the slot up at a later date. Note: I'm aware that the mounting tab is not triangulated. I wil do that after I have a driveshat made up. I need to be sure I have enough clearance for the yoke and universal. Also, the shaft sticking out of the transmission is not going to be used. I just cut down the original output shaft for mock-up purposes. Tranny will be coming out eventually for a rebuild and shorty planetary set.
Rolling chassis with motor and trans bolted. I'm hoping to get the body mounted in the next month or so.
Old August 22nd, 2010, 11:32 AM   #172
kruzh
kruzh's Avatar
nice
kruzh is offline   Reply With Quote
Old August 22nd, 2010, 12:06 PM   #173
roll-bar Bob
roll-bar Bob's Avatar
where in the hell are you going to fit ?????
setting on the trans ????
or rear end ???
Old August 22nd, 2010, 01:17 PM   #174
hellspawn
hellspawn's Avatar
nice cant wait to see it done
hellspawn is offline   Reply With Quote
Old August 22nd, 2010, 07:13 PM   #175
Nuggets
I fix stuff!
Nuggets's Avatar
or rear end ???
I will be sitting just ahead of the rear axle. This will be a single seat car.
Old August 25th, 2010, 12:47 AM   #176
Nuggets
I fix stuff!
Nuggets's Avatar
With the addition of one more heim joint, the steering will be done. I've plated all the open tube ends on the main frame so now there is only one thing left to do.......
Stuff the frame into the body
I will be hacking the floor out of the Honda in a few days. I have to take some time off to stuff a trans in a Jetta.
Old August 25th, 2010, 01:23 AM   #177
Bc1980
must just be the pictures perception looks like the motor sits behind the windshield????
bad ass project
Bc1980 is offline   Reply With Quote
Old August 25th, 2010, 02:08 AM   #178
Nuggets
I fix stuff!
Nuggets's Avatar
bad ass project
Yes it does. The car is too narrow to fit the V8 under the hood and still have a front suspension. This is a very small car.
Old August 25th, 2010, 09:22 AM   #179
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Im a small dude and even I think Id have trouble getting into this car Keep up the good work.
I'm the man in White.
Old August 25th, 2010, 10:02 AM   #180
Nuggets
I fix stuff!
Nuggets's Avatar
I'm 5' 11". It will be a very tight fit but I don't care. Sometimes you have to suffer a little bit to enjoy the glory. Seriously, I know the car will be miserable to drive for more than a few miles. Why I build shit like this, I don't know, but I like it.
Page generated in 0.58662 seconds with 84 queries
