1972 Honda AZ 600 upgrade. - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Should I make a rat rod out of my turd Honda or fix it up.
Rat Rods are what cool, and besides, everything Nuggets owns looks like a rat rod. 41 38.68%
For the love of God, put some effort into this project and fix it up. 46 43.40%
I'm a closed minded a-hole who will make nasty comments because I'm jealous. 19 17.92%
Voters: 106. You may not vote on this poll
Old November 24th, 2009, 01:38 AM   #61
Nuggets
I fix stuff!
Nuggets's Avatar
Here is before axle reduction surgery.
In process.
This is after surgery. This is just a mock up. I will be doing the final assembly when I get my axle shafts back from Moser. Yes the pumpkin is off center. I set the rear axle up so that the pinion will be centered so I don't have a compound angle in the driveshaft.
Old November 24th, 2009, 07:08 AM   #62
sandman86
sandman86's Avatar
i thought doing this to a zx3 focus would be nutty.... you take the cake
you Sr, are my hero.
sandman86 is offline   Reply With Quote
Old November 24th, 2009, 11:33 AM   #63
four_by_ken
Need a strap?
four_by_ken's Avatar
There is already a company that makes kits to put a V8 in a Focus and make it RWD.
This build is way over the top compared to the Focus build.
four_by_ken is offline   Reply With Quote
Old November 24th, 2009, 04:51 PM   #64
BlooMule
Old School
BlooMule's Avatar
Makes me think of Hot Rod's 500cid Caddy powered Chevette.....
Old November 24th, 2009, 10:03 PM   #65
redram98
redram98's Avatar
this build is absolutly ass kicking.
redram98 is offline   Reply With Quote
Old November 24th, 2009, 10:06 PM   #66
Nuggets
I fix stuff!
Nuggets's Avatar
I'd like to read that article. I've seen numerous V8 Chevettes at the drag strip over the years. I remember a very nice one that was street legal with a blown sbc. If I remember right, it ran in the 10's.
At one time I was going to build a rear engine, rear drive V8 Yugo using a standard 2wd tranny, boat V-drive, and regular rear end. That project never got off the ground.
There are several things about this project that make it different. The car is somewhat rare, it's very small, and I don't think it's been done before.
Old November 24th, 2009, 10:14 PM   #67
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I for one give you credit for building different...hats off sir!
Old November 24th, 2009, 10:48 PM   #68
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
giant burnout when its done or its junk!
Old November 24th, 2009, 10:49 PM   #69
Nuggets
I fix stuff!
Nuggets's Avatar
Don't you worry about that sunshine. I plan on beating the snot out of this thing.
Old November 24th, 2009, 10:51 PM   #70
unclebeaner
sunshine? shucks you did remember
Old November 25th, 2009, 06:48 AM   #71
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
In process.
WTF? Driveshaft? Ain't gonna be no room! You're going to have to make the motormounts pivot (transversely) and make the engine/trans/rearend all one suspension component.
You go Girlfriend.
@clarkstoncracker
Old November 25th, 2009, 07:03 AM   #72
Nuggets
I fix stuff!
Nuggets's Avatar
You go Girlfriend.
I actually thought about doing that at one time. I will have enough room for a driveshaft by using a modifed powerglide trans. The total trans length when I'm done with it will be about 17 inches. That will give me about a 11 in driveshaft. Since the rear suspension travel is only goint to be a few inches, I'll be ok with that. I talked to my driveline guy before the build and he said that length would be ok. He's also the one that suggested offsetting the rear diff so the pinion would be centered and the driveshaft would be correctly aligned.
This is my secret weapon for the build. I will be building my own but you get the idea. These trannys are very short.
I'm glad you guys find this build interesting. I personally am enjoying trying to make all this stuff work. I am taking the experience from building the Metro and applying it to this vehicle. This is really only my second "from scratch" car build.
Old November 25th, 2009, 07:10 AM   #73
curt1656
Praise the lowered
curt1656's Avatar
Oh, I thought the pumpkin was offset for oval track races.
Old November 25th, 2009, 07:14 AM   #74
Nuggets
I fix stuff!
Nuggets's Avatar
Turning will not be this car's strong point.
Old November 25th, 2009, 07:50 AM   #75
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
@clarkstoncracker
Old November 26th, 2009, 01:08 AM   #76
sandman86
sandman86's Avatar
x2
still looking forward to the completed project.
Old November 26th, 2009, 03:14 AM   #77
unclebeaner
your gonna look like a monkey fucking a football in that thing
Old November 26th, 2009, 03:59 AM   #78
Ebs
Tech-ish Question: Does having the pinion offset really affect anything? Meaning, for a conventional driveshaft as long as the u-joints are within proper operating angles does it matter what direction the driveshaft is pointed?
Cool build, I like
Old November 26th, 2009, 08:12 AM   #79
Nuggets
I fix stuff!
Nuggets's Avatar
Cool build, I like
My driveline guy suggested offsetting the pumpkin like this. I mocked up a set of standard offset steel wheels with 195/65-15 tires on them last night and I feel I'm still alittle close to the body exterior with the outside edge of the wheel. I'm been doing some research and I think I've found a way to run a compound angle. If I can pull off the compound angle thing I am going to shorten the right side tube some more and center the diff.
Keep in mind I'm not a building or fabrication god. I am just a dude with a big welder and a desire to build wierd stuff. I am learning as I go so there will be changes made to this project on the fly.
Old November 26th, 2009, 08:43 AM   #80
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
short wheelbase + 500hp = with a (instead of a ) up its butt.
@clarkstoncracker
Page generated in 0.36550 seconds with 84 queries
