97-04 TJ Dana 30 front axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2009, 06:27 PM   #1
silverz
Default 97-04 TJ Dana 30 front axle
As the title says im looking for a front axle for a 2001 TJ Wrangler. Shoot me some prices and pics if you have them. Thanks!
Email is dmarshallt@yahoo.com
silverz is offline   Reply With Quote
Old August 28th, 2009, 08:28 PM   #2
Rubilooe
Rubilooe's Avatar
Default Ratio
ratio ?
Rubilooe is offline   Reply With Quote
Old August 28th, 2009, 08:45 PM   #3
GerkTJ
GerkTJ's Avatar
need just the housing or complete?
GerkTJ is offline   Reply With Quote
Old August 29th, 2009, 07:03 AM   #4
silverz
Originally Posted by Rubilooe View Post
ratio ?
dont care about the ratio, i can just put mine in. keep it if you like.
Dont think it matters, my buddies girl got into an accident with her jeep. As far as i can tell the axle and the steering arm is the only thing damaged.
So i have everything to put in it i just need it from knuckle to knuckle, Straight with no bent or damages brackets.
Hope this helps.
Old August 29th, 2009, 04:04 PM   #5
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
dunno if u know or not but i believe it was in 00, they swapped to low pinion so i don't think u'd be able to just swap the gears if that was the case and i'm not sure about this at all but if u went to a high pinion from a low pinion u may have issues with ur front drive shaft length
coolgareray is offline   Reply With Quote
Old August 29th, 2009, 05:23 PM   #6
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
pm itchy he has a extra on laying around
Page generated in 0.23624 seconds with 41 queries
