Body Protection - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2009, 04:15 PM   #1
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
Arrow Body Protection
When bolting rocker guards or rear corners to your tub do you use anything in between the tub and guard or do you just bolt it straight on? I would think that would make a good place for rust to form. But even if you used cork or something it would just hold the moisture there longer. Anyone have any problems with either way? Thanks
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old August 28th, 2009, 04:23 PM   #2
Pokerob
hug life
Pokerob's Avatar
~Bry
why not just use a bead of rtv on the back of the armor then bolt it on?
Old August 28th, 2009, 11:20 PM   #3
jeepnxj96
jeepnxj96's Avatar
x2
Old August 28th, 2009, 11:30 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
lots of rtv/silicon.
Old August 28th, 2009, 11:34 PM   #5
xjmichigan
xjmichigan's Avatar
clear silicone
speaking of which, I am shopping for rear quarter protection, am I not seeing it on JCRs website?
Old August 28th, 2009, 11:48 PM   #6
All5ofus
All5ofus's Avatar
http://www.rokmen.com/products/corne...b_corners.html
These are the best deal I found when I got mine. I did a lot of looking around.
I took mine down to a local body shop and had them painted for just $50.
And to answer the question I went with no layer between the metals. I was told it would trap dirt and such. I found this to be true when I removed my rocker guards to re paint that I did you caulk on.
All5ofus is offline   Reply With Quote
Old August 28th, 2009, 11:56 PM   #7
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
Originally Posted by All5ofus View Post
I was told it old helps trap dirt and such. I found this to be true when I removed my rocker guards to re paint that I did you caulk on.
GET YO DRINK ON BRUTHA!!!
OP: .. I used a 3/16" Rubber "Gasket" that was the full size as my rockers to put in between.
nixxerRsixxer is offline   Reply With Quote
Old October 28th, 2010, 06:31 PM   #8
schanxj
schanxj's Avatar
Where did you get the rubber and what is a good price for it?
schanxj is offline   Reply With Quote
Old October 28th, 2010, 06:57 PM   #9
hotwired
Look for an industrial supply store in your area. We have West Michigan Rubber here, they can get just about anything you want. I'm kind of curious about ice and snow shield for roofing. It's not a tar paper, more like a rubber and it has adhesive on one side that would grip about anything. It will peel off and any remnants should come clean with wax and grease remover. If you know anyone that does roofing you should be able to get a couple of scrap pieces cheap or free.
hotwired is offline   Reply With Quote
Old October 28th, 2010, 10:47 PM   #10
Yota Bill
this stuff sounds interesting, thinking there could be alot of uses for it...I'm assuming its fairly thin, any idea of the thickness? Can this be found at places like Home Depot or Menards?
Old October 29th, 2010, 01:30 PM   #11
jimmyroyse
webwheeler
jimmyroyse's Avatar
I haven't tried it yet, but I was told that urethane windshield sealer works great.
jimmyroyse is offline   Reply With Quote
Old October 29th, 2010, 01:39 PM   #12
OldSlowReliable
extra on the SLOW
OldSlowReliable's Avatar
AKA poor man's sound proofing...fyi
Idk about removability, but its fairly cheap and a waterproof..
OldSlowReliable is offline   Reply With Quote
Old October 30th, 2010, 02:14 PM   #13
ChadSmeltzer
ChadSmeltzer's Avatar
We get it at Home Depot, but it's like $100/roll and there is a lot of it. I do think it could work for this though. I would say it's about 1/8" thick. GAF stormgaurd has the rubber on one side.
Don't use RTV if you ever plan on removing it. I have seen aftermath pictures of that where it pulled the body panels out with it, leaving them bowed pretty bad.
LuckyCharm, you live by 131 right? I go by there daily and could bring you a few feet of it if you want to try it.
04 TJ - 35's, locked, 4link
ChadSmeltzer is offline   Reply With Quote
Page generated in 0.46820 seconds with 62 queries
