98 350 vortec HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2009, 06:12 PM   #1
02jeepX
02jeepX's Avatar
Default 98 350 vortec HELP
I have a 98 chevy with a 5.7L vortec that went bad. My question is can I use a 94 short block and bolt on my heads, intake, etc, and have all the bolt patterns line up. Can this be done?
02jeepX is offline   Reply With Quote
Old August 27th, 2009, 08:36 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Physically, yes it all bolts up. Will it work? No, not without some work. Your 98 has a crank sensor in the timing cover, the 94 does not.
Old August 27th, 2009, 08:47 PM   #3
montecarlo0992000
put the timing cover from the vortec on it and the knock senseor boly on your heads and go
montecarlo0992000 is offline   Reply With Quote
Old August 27th, 2009, 08:56 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Not that easy. The timing set is different; thinner and odds are the timing sets won't swap because the 98 is a roller cam and has a retainer plate behind the cam gear. The plate the crank sensor sees is between the balancer and crank gear behind the cover.
Can it be swapped? Yes, given time and some money. For a quick swap, get the proper engine.
Old August 28th, 2009, 09:15 AM   #5
Tom
Because racecar
Tom's Avatar
The front of the block where the timing is different.... so the answer is no.
You need to use the front cover from the 98 because it has the provisions for the crank sensor. The front cover from the 98 will NOT bolt up to the 94.
Old August 29th, 2009, 07:08 AM   #6
davidkassie
davidkassie's Avatar
i installed a new engine in a 99 tahoe, the new engine had the old timing cover set up, with the fuel pump boss open like the old style, bolted a block off plate to it, installed the new style timing cover and reluctor wheel off of the old one, worked fine, runs everyday! good luck with yours, not staying it will work for sure, but i've done it. david
davidkassie is offline   Reply With Quote
Old August 30th, 2009, 06:19 PM   #7
02jeepX
02jeepX's Avatar
did the timing cover off of the 99 bolt up to the older block. what year block did you use?
Old August 30th, 2009, 06:49 PM   #8
davidkassie
i didn't check the exact year of the block i used, but it had the old bolt pattern for the timing cover, the new cover blocks the old holes
Old August 31st, 2009, 07:35 PM   #9
02jeepX
02jeepX's Avatar
so did you drill and tap for the new holes on the old block?
Old August 31st, 2009, 07:40 PM   #10
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Nobody ever bothered to point out that vortec motors have roller lifters as well?
TBI motors rev limit at 4500 or 5000 rpm, I could be wrong but I'm pretty sure vortec motors rev higher.
1988JeepXj is offline   Reply With Quote
Old August 31st, 2009, 07:53 PM   #11
davidkassie
does the rev limiter really matter? they make plenty of power below 5000, and no the vortec timing cover uses the current holes and bypasses two or 4 of the old ones, yes it has roller lifters but the intake bolts on the same, so an exact swap no, noticeable difference, probably not as long as it has the good heads! david
Old August 31st, 2009, 08:06 PM   #12
jbsjunk
Little Member
jbsjunk's Avatar
See post #4.
From what I understand, the older steel cover will go on the 97+ block, but a few of the holes are not drilled/tapped but the boss's are there. The newer plastic cover would go on the older block and use existing holes, but not use them all.
Old August 31st, 2009, 08:10 PM   #13
davidkassie
exactly, thats what he wants to do is use the newer parts on the older motor, right? if so than yeah it should all work
Old September 1st, 2009, 07:19 PM   #14
02jeepX
02jeepX's Avatar
Thanks guys I think I'll give it a try.
Old September 1st, 2009, 07:24 PM   #15
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
your better off just getting another vortec 350, there is a couple on nmi craigslist from parts trucks
Old September 2nd, 2009, 03:05 PM   #16
02jeepX
02jeepX's Avatar
All the ones on craigslist around me I have called and they either need work like mine does or they want a grand or better for.
Page generated in 0.28842 seconds with 71 queries
