No Idea whats wrong!!!??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2009, 12:24 PM   #1
j_little3
Boris
j_little3's Avatar
Default No Idea whats wrong!!!???
I was at silverlake on sunday and in the middle of my trip my truck was boging out at low rpm's. I cant figure out what is wrong. I thought i had water in my tank but i put water dry in and added more gas but nothing. If i get on the gas it will bog then all of a sudden it will "grab" then its fine if i keep it to the floor. Its not the tranny cuz the rpms go up it feels likes its running on 3 cylinders. I know im getting plenty of gas because my check light flashes which means i have more gas going in than it can burn. It will usually stop after a few miles and be fine. Whats wrong?
j_little3 is offline   Reply With Quote
Old August 27th, 2009, 12:26 PM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Your check engine light flashes and that means you are getting more fuel than it can burn? Don't think I've ever heard that one before.
Old August 27th, 2009, 12:32 PM   #3
Chip Wheeler
Chip Wheeler's Avatar
FWIW, one of my friends had the same problem and it ended up being a plugged cat.
Chip Wheeler is offline   Reply With Quote
Old August 27th, 2009, 12:37 PM   #4
IFS SUCKS
I like trees
IFS SUCKS's Avatar
X2
IFS SUCKS is offline   Reply With Quote
Old August 27th, 2009, 01:40 PM   #5
jmw55018
Oh poop
jmw55018's Avatar
hollow out that cat..... or if you want to be all legal like replace it
jmw55018 is offline   Reply With Quote
Old August 27th, 2009, 05:24 PM   #6
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Check your ignition parts....and gut out the cat or just get a performance cat (pretty much a gutted cat, but it's legal
Old August 27th, 2009, 05:27 PM   #7
redxj_07
redxj_07's Avatar
x2
I would go with the plugged cat. that was my problem when my truck did what you are describing. Bore the thing out and call it good.
redxj_07 is offline   Reply With Quote
Old August 27th, 2009, 07:07 PM   #8
davidkassie
davidkassie's Avatar
try cleaning the mass air flow sensor, use carb clean or throttle body/mass air cleaner from 3m, sometimes it affects low rpm running, either that, fuel fitler, fuel pressure, cap/rotor, or plugged cat, what year was the truck?
davidkassie is offline   Reply With Quote
Old August 27th, 2009, 07:24 PM   #9
j_little3
Boris
j_little3's Avatar
I dont have cats... lol but its a 1996. I just changed the plugs and wires less than 1 month ago.
Old August 27th, 2009, 07:36 PM   #10
Disturban
Disturban's Avatar
You are joking about this right? Scan it...that will probably tell you way more then we can!
Old August 27th, 2009, 07:45 PM   #11
j_little3
Boris
j_little3's Avatar
i did scan it im not retarded. the scan said nothing that helped me. are you trying to piss me off
Old August 27th, 2009, 07:55 PM   #12
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Check your fuel filter. If it's getting plugged, it'll cause bad bogging too. A flashing CEL is usually an indication of a mis-fire.
Old August 27th, 2009, 07:59 PM   #13
adamzr2
numero douce undela
adamzr2's Avatar
mine blinked when iy miss fired
adamzr2 is offline   Reply With Quote
Old August 27th, 2009, 08:48 PM   #14
davidkassie
the only reason the mil blinks is when the engine is missfiring bad enough to cause catalytic convetor damage, probably in the dist. cap and rotor. make sure to check the play in the dist. seen the dist drive gear worn badly on these engines
Old August 27th, 2009, 09:12 PM   #15
Disturban
Disturban's Avatar
Not trying to piss you off I am trying to help you. Check engine lights dont blink because of to much fuel they blink because of a misfire. What year is your truck? 1996 and newer will tell you what cyl is misfiring. That will point you to a bad plug wire or plug on that cylinder...however if the scan did not point to one bad cyl I would suspect a bad coil, ignition module or pick up coil. Any of these would cause a misfire on random cylinders and make the check engine light blink. This is not going to be a fuel system or cat converter problem...it is definitely an ignition problem.
EDIT: What did the scanner tell you?
Old August 27th, 2009, 09:45 PM   #16
jmw55018
Oh poop
jmw55018's Avatar
Originally Posted by Disturban View Post
Not trying to piss you off I am trying to help you. Check engine lights dont blink because of to much fuel they blink because of a misfire. What year is your truck? 1996 and newer will tell you what cyl is misfiring. That will point you to a bad plug wire or plug on that cylinder...however if the scan did not point to one bad cyl I would suspect a bad coil, ignition module or pick up coil. Any of these would cause a misfire on random cylinders and make the check engine light blink. This is not going to be a fuel system or cat converter problem...it is definitely and ignition problem.
x2 if you dont have any cats on it to plug up and its not fuel related this is the next place to look
Old August 28th, 2009, 07:17 AM   #17
davidkassie
X2, very rare,but could also be an injector failure, have seen the injectors fail on the spider injector
Old August 28th, 2009, 10:24 AM   #18
redxj_07
redxj_07's Avatar
dont use carb cleaner as it will damage the sensors. you need something that is designed for cleaning the sensor like mass air cleaner. Not trying to point a finger at davidkassie, just making sure you dont hurt something
Old August 28th, 2009, 12:32 PM   #19
davidkassie
i've heard that but i've done it a cple of times, i do recommend 3m t-body cleaner, no offense taken red! david
Old August 28th, 2009, 12:36 PM   #20
blazn4dr
blazn4dr's Avatar
My blazer acted like that and ended up being the fuel pump
blazn4dr is offline   Reply With Quote
Page generated in 0.39640 seconds with 83 queries
