99 S-10 4.3 fuel pressure - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2009, 08:51 AM   #1
General Motors
Fuck cancer
General Motors's Avatar
Default 99 S-10 4.3 fuel pressure
A friend of mine needs to know what fuel pressure his truck should be running at. He doesn't own a Haynes book so I thought I would ask on here. I told him to buy a guage too. I read somewhere on here that it should be @ 60 p.s.i., is this correct? Thanks!
General Motors is offline   Reply With Quote
Old August 27th, 2009, 09:10 AM   #2
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
58 psi is where mine was at last time it was checked.
JohnL is offline   Reply With Quote
Old August 27th, 2009, 09:11 AM   #3
stunya
NM...looks like you got an answer.
stunya is offline   Reply With Quote
Old August 27th, 2009, 12:06 PM   #4
davidkassie
davidkassie's Avatar
and these fuel injection systems are very picky about pressure, no less that 58lbs. anything less, check filter for restriction, then plan on installing new pump! david
davidkassie is offline   Reply With Quote
Old August 27th, 2009, 06:45 PM   #5
Disturban
Disturban's Avatar
Spec is between 60 and 66 psi and as stated they are very picky about fuel pressure. If you are just a little below 60 I would try a new fuel filter first.
Old August 28th, 2009, 10:35 PM   #6
General Motors
Fuck cancer
Thanks guys! I will forward the info. right away! Appreciate it!
Page generated in 0.21547 seconds with 41 queries
