208 t-case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2009, 09:09 PM   #1
davidkassie
davidkassie's Avatar
Default 208 t-case
anybody running this t-case? 1987 blazer, seems to have slop in chain, is this common? makes noise is freewheeling, any suggestions?
davidkassie is offline   Reply With Quote
Old August 26th, 2009, 09:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
208s are decent unless your putting alot of power through them. then they show their weakness. chains usually develop looseness after time. anything with high miles will make noises and be worn out. a rebuild kit isn't that expensive IIRC.
Old August 26th, 2009, 09:39 PM   #3
davidkassie
cool thanks, i removed it from a plow truck, when you let off the gas, in free wheel it makes a wierd vibration noise, has no driveshaft vibe at higher speeds, just in let off, is a rebuild kit with a chain cheaper than just gettin another used one? its for a th400
Old August 26th, 2009, 10:53 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well a used one will be cheaper but then your still stuck with a used t-case that will eventually give you the same trouble again.
Page generated in 0.13365 seconds with 35 queries
