98 durango gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2009, 04:15 PM   #1
prozak1986
prozak1986's Avatar
Default 98 durango gears
my friends got a 98 durango and hes looking to know what gears he has in it , the only thing the tag says on the rear diff is 32 , i did a quick google search and only thing i found out 3.55 and a 3.92 for 4x4 any one know what the 32 stands for ?
prozak1986 is offline   Reply With Quote
Old August 26th, 2009, 05:57 PM   #2
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Call the dealer with the vin and if they are the stock gears they will be able to tell you what they are.
GNJEEPN is offline   Reply With Quote
Old August 26th, 2009, 06:31 PM   #3
prozak1986
prozak1986's Avatar
i called a dealer before i posted this and they said hed have to bring it in because they dont have that kind of info anymore , were doing his rear diff gasket this weekend anyways so ill probably count teeth on the gears and post what i find out
Old August 26th, 2009, 07:04 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
roll the vehicle in neutral. if one full turn of the tire=3.5 turns of the drive shaft then it is 3.55. 3.9 turns of the shaft is 3.92.
id bet its 3.55, thats way more common.
good luck
Old August 26th, 2009, 07:33 PM   #5
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
BS I work at a Dodge dealer. They were just blowing you off. Try another dealer. Ask for the parts dept. They will be able to give you all the info. In fact if you ask nice they can print off an entire build sheet on the vehicle.
Old August 28th, 2009, 04:30 PM   #6
Red Ram01
Mr Ohara
Red Ram01's Avatar
Send a message via AIM to Red Ram01
well are you sure it didnt say 3.2?
Red Ram01 is offline   Reply With Quote
Old August 29th, 2009, 09:45 AM   #7
prozak1986
prozak1986's Avatar
it could have , truck was dirty so its posible
Old September 1st, 2009, 10:42 AM   #8
prozak1986
prozak1986's Avatar
found out yesterday is a 3.55
Page generated in 0.22134 seconds with 47 queries
