Info on "609" axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2009, 09:58 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default Info on "609" axle
The "609" and why.
I will be searching after I post this.
What are the benefits of this hybrid axle?
Any links you can steer me to as to the benefits and hopefully a buildup?
Old August 24th, 2009, 10:03 PM   #2
boggin-machine
boggin-machine's Avatar
Expensive
Old August 24th, 2009, 10:07 PM   #3
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
The "609" and why.
Pros: light weight & very strong
Cons: Expensive!
Monkeyevil on here is building one
I'm the man in White.
Old August 24th, 2009, 10:14 PM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Cons: Expensive!
Built.
JcrOffroad
Zoom Zoom!
Old August 24th, 2009, 10:18 PM   #5
mpwal099
Stick it up your ass
mpwal099's Avatar
Originally Posted by Monkeyevil View Post
Built.
is that an oil cap for the fill plug?
mpwal099 is offline   Reply With Quote
Old August 24th, 2009, 10:21 PM   #6
boggin-machine
no its not. they sell plugs like that for the diamond housing to make it easier to full and bling factor.
Old August 24th, 2009, 10:22 PM   #7
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
http://www.jegs.com/i/JEGS/555/60136/10002/-1
JcrOffroad
Zoom Zoom!
Old August 24th, 2009, 10:22 PM   #8
firehawk
Live Action!
firehawk's Avatar
So it consists of a
9" center section
HP60 C's and knuckles, etc.
New tubes
Does it use a stock 9" third? Or what?
Old August 24th, 2009, 10:26 PM   #9
mpwal099
mpwal099's Avatar
cool. me likey.
Old August 24th, 2009, 10:27 PM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Yep, 35 spline 9" third with d60 inner shafts.
Custom inner 60 shafts without the larger OD seal shaft are required.
Or cut down OEM 60 shafts polished for a seal.
Technically you could run a 31 spline 9" third with custom 60 shafts... but that would be silly.
My main motivation was strength without loosing ground clearance. The weight is just a bonus.
This was my front d44.
This is the shaved 9" center.
JcrOffroad
Zoom Zoom!
Old August 24th, 2009, 10:33 PM   #11
firehawk
Live Action!
firehawk's Avatar
Been finding alot of info on Pirate.
And thanks for the replies. I learned something new today.
How much stronger is the 9" compared to the D60? The weight has to be a big advantage too?
Old August 24th, 2009, 11:08 PM   #12
jmdzuk
jmdzuk's Avatar
It all depends.... A 60 is pretty dumb proof put it in close your eyes and go
A ford hi pin is pretty tough to beat for the money.
a 609 is way cool and $$$$ if you are trying to make the same strength as a 60.
But if you want good ground clearance and are not going to run huge heavy tiers you could play some games with te 9" to save a little money to get started.
I have not built one my self such as Monkey has but I bet he will love it.
jmdzuk is offline   Reply With Quote
Old August 24th, 2009, 11:11 PM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
A standard 9" ring and pinion is arguably weaker overall than a d60 ring and pinion. I think the way the teeth are cut in the 9" makes the actual teeth stronger, and the 3 bearings on the 9" pinion mean with a strong housing there is less gear deflection.
This can be combatted with running a strong aftermarket third member in the low pinion configuration, or running True-Hi 9's beefy high pinion third which includes a set of very strong gears.
JcrOffroad
Zoom Zoom!
Old August 24th, 2009, 11:30 PM   #14
boggin-machine
monkey if you dont mind what kinda money do you have into one with a break down if you can do all your own welding
Old August 24th, 2009, 11:32 PM   #15
firehawk
Live Action!
firehawk's Avatar
What rear axles compliments the 609? For ground clearance and strength?
Old August 24th, 2009, 11:32 PM   #16
firehawk
Live Action!
firehawk's Avatar
Originally Posted by boggin-machine View Post
Expensive
Who cares, I will make more tomorrow.
Old August 24th, 2009, 11:33 PM   #17
boggin-machine
the usual 14 shaved seems to come to mind with a 5 lug pattern or the 8 if you perfer? id run 8 lugs all around but it seems pretty common most guys that run the 609 like to be a little different and run the 5 lug pattern
Old August 24th, 2009, 11:35 PM   #18
boggin-machine
i say the same thing but i always get dirty looks or hit from the lady. so since we on the subject sell my the tj back for next to nothing it wont be that big of hit you will make the rest back next week.
Old August 25th, 2009, 12:42 AM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I run a 35 spline semi float 9".
JcrOffroad
Zoom Zoom!
Old August 25th, 2009, 12:51 AM   #20
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I made some stuff, waited for deals, and got some stuff on trades for parts and product, but I can quote retail guess on stuff.
9" housing $50
Chevy d60 inner knuckles, outers, spindles, & hubs $400
Superior 35 spline inners $450
Superior 35 spline outers $450
Stock Spicer 60 joints $100
Strange third $225
Detroit Locker $475
9" Gears $125
9" Install kit $100
Aluminum pinion support (Daytona) $100
Inner axle seals $60
DOM tube for housing $75
Kingpin rebuild kits $150
Wheel bearings & seals $125
Drive flanges $200
Rotors $75
Calipers $40
Pads $20
Turn down hubs for 6 on 5.5 $40
Brake brackets $75
High steer arms $200
Inspection cap $25
Wheel studs $30
$3590 estimate I guess...
JcrOffroad
Zoom Zoom!
Page generated in 0.45357 seconds with 83 queries
