firing new BBC tonight, any tips? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2009, 03:34 PM   #1
DUNE JUMP
DUNE JUMP's Avatar
Default firing new BBC tonight, any tips?
Going to prime oil pump, rotate engine 1/4 turn at a time to get all the lifters
set engine to 16 deg BTDC on #1 after compression stroke, distr pointing to #1 plug wire
gapping plugs to .040
have carb filled with fuel, and primed the squirters
still have to fill tranny fluid and P/S fluid, and water/coolant
have all my gauges wired up
bottle of Cam saver in the oil
Anyone in Clawson tonight who hears a lot of ruckus for 20 min, be nice, don't call Clawson's finest
Any other tips?
Old August 24th, 2009, 03:39 PM   #2
guest
Send a message via AIM to guest
Haha have fun man!! Just check your oil like a million times before you start it up. I checked mine probably ten times before I fired it up. And have a extra pair of hands available and water like ahose or fire extinguisher just in case.
guest is offline   Reply With Quote
Old August 24th, 2009, 06:00 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
have a fire extinguisher near by just in case. have and extra set of eyes looking under it for leaks. prime it for a real long time. someone watch the oil pressure guage closely.
good luck!
joe_jeep is online now   Reply With Quote
Old August 24th, 2009, 06:14 PM   #4
Tom
Because racecar
Tom's Avatar
Make sure the trans has fluid in it, or you'll destroy the pump.
Old August 24th, 2009, 06:19 PM   #5
aber61
aber61's Avatar
Be sure to have a good ground to the frame
aber61 is online now   Reply With Quote
Old August 24th, 2009, 07:58 PM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I alwyas prime my pump with a 1/2" makita drill with the valve covers off. And I WILL NOT start it until there is atleast 30 psi on the mechanical oil guage. And it also has to have oil coming out of every weep hole in the rocker arm.
Old August 24th, 2009, 08:06 PM   #7
luvitmyjeep
broken
luvitmyjeep's Avatar
a lesson learned the hard way by a Friend of mine! the second time we primed a little past good enough then a little more.
luvitmyjeep is offline   Reply With Quote
Old August 25th, 2009, 11:33 AM   #8
DUNE JUMP
DUNE JUMP's Avatar
good advice guys, thanks!
going to do some more priming tonight.
Page generated in 0.24284 seconds with 47 queries
