1999 malibu engine codes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2009, 09:49 PM   #1
upchuck
upchuck's Avatar
Default 1999 malibu engine codes
Is there a way with the ignition key etc to retrieve a code in the odo much like a wrangler or do you need an OBD reader in the port? Help?
upchuck is offline   Reply With Quote
Old August 22nd, 2009, 09:58 PM   #2
Freak
Wheelin the HD
Freak's Avatar
there are 2 pins you can jump and it will flash the codes, or swing by autozone and they can read the codes, or, I have a scanner...
Old August 25th, 2009, 08:31 PM   #3
davidkassie
davidkassie's Avatar
dont jump anything! go to autozone or a repair shop, usually obd 2 doesn't have an option for "jumping the aldl" to retrieve codes, good luck, running bad or ses light?
davidkassie is offline   Reply With Quote
Old August 25th, 2009, 08:44 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
hes correct. if you try and jump 2 pins you run the risk of shorting out the pcm. that would be very bad. you can only jump pins on a gm up till all 94 and some 95's
Old August 25th, 2009, 08:44 PM   #5
Yota Bill
X2
the reason for OBD2 was to make all vehicles uniform, so a single reader/scanner would work on all of them (in theory), so there was no need to design in a way to retrieve codes without the tool.
Page generated in 0.24051 seconds with 38 queries
