1 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2009, 10:51 PM   #1
deerebowtie
Unchained
deerebowtie's Avatar
Default 1
23
Old August 21st, 2009, 12:15 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i kinda doubt the stocker will have enough volume for both. you could run dual pumps if it's needed.
Old August 21st, 2009, 01:57 PM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
WTF are you building??
Old August 21st, 2009, 07:04 PM   #4
jmw55018
Oh poop
jmw55018's Avatar
you might run into volume issues, ive used power steering pumps to run lift cylinders for snow plows and misc. other crap and it all worked ok thow. depending on the line size you go with you might be ok.
jmw55018 is offline   Reply With Quote
Old August 23rd, 2009, 01:43 AM   #5
Yota Bill
you wont be able to run them both off of the same pump, tried it on another guys truck... basically, the oil has to flow through the orbital valve and return to tank, which means no pressure...the hydroboost does basically the same thing, so if either of them are not being used, there is no system pressure...you would need some sort of priority valve to make it work, which isnt going to work very well with that type of pump
and yes, I do know a little about hydraulics, since I work on hydraulic systems on a daily basis
Old August 23rd, 2009, 11:00 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I ran hydro boost brakes and ram assist on my cj, it worked great, but an assist ram may be too small for your application... maybe not.
Page generated in 0.24030 seconds with 41 queries
