What T-case? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2009, 06:10 PM   #1
Slayer63
Upstanding Member
Slayer63's Avatar
Exclamation What T-case?
Im getting closer and closer to my sfa swap but i still need to answer a few questions. i am going to run chevy axels, the 14bff is already in. my question is what t-case can i use for my chevy d60? is there anyway i can run a t-cse without an adapter? are any of the new process t-cases bolt in? im thinkin 205, any sugestions? im have a 4l60e it that helps.
Slayer63 is offline   Reply With Quote
Old August 21st, 2009, 11:18 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can get a 91 and down 241 t-case from a k-5 blazer. they are passenger side drop and manual shift. they used the 700r4 which is identical to the 4l60e IF you have a early model.
Old August 21st, 2009, 12:29 PM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
First off what is the vehicle? What tranny are you gonna run?
If you want strong go w/ a NP205 its part time and gear to gear. Anything else is gonna be chain and weaker!! Haven't seen a 205 brake but i've seen chains brake in the case before.
Old August 21st, 2009, 12:34 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
one problem. he said he doesn't wanna use an adapter. 700r4 to 241 was a factory combo and can be had from many trucks.
Old August 21st, 2009, 12:56 PM   #5
Hoss Blazer
!SPARTY ON!
Ya i didn't know what year, make and model it was because he didn't have that listed. I would try to find a combo on here for sale. I saw a TH400/NP205 a couple days ago!! But then the computer is gonna be all screwed up. Unless you switch to carb.
Old August 22nd, 2009, 01:39 PM   #6
Slayer63
Upstanding Member
Slayer63's Avatar
its a 95 k1500 with the 4l60e.
Old August 22nd, 2009, 04:59 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yea you can bolt a 241 right to your trans using a factory adapter from a k-5 blazer. easy setup
Old August 23rd, 2009, 10:27 AM   #8
Slayer63
Upstanding Member
Slayer63's Avatar
thanks man, just what i wanted to hear.
Old August 23rd, 2009, 12:02 PM   #9
redline8300
Redline8300
redline8300's Avatar
Try a divorced 205.
redline8300 is offline   Reply With Quote
Old August 23rd, 2009, 01:09 PM   #10
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
here you go. even has the adapter you need. 208=241 just fyi
NP 208 for the 700R4 $50 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 23rd, 2009, 02:53 PM   #11
Ebrown
Ebrown's Avatar
27 spline Np 208 or 241 will bolt to the 4l60E or 700r4.. The 208 has 2.61.1 low range and the 241 has 2.72.1 low range.. The 241 is stronge by design..
Ebrown is offline   Reply With Quote
Page generated in 0.21090 seconds with 57 queries
