help me weld? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2009, 12:37 PM   #1
boggi
wen in doubt throttle out
boggi's Avatar
Send a message via MSN to boggi
Default help me weld?
hey guys ive been wanting to patch a whole inthe floor of my new '79 bronco, and i tried the welder out on a scrap peice of metal for the first time and this is how it turned out
i touch the metal as gently as possible but it still sticks on, can someone help please
thanks
boggi is offline   Reply With Quote
Old August 20th, 2009, 12:42 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Um.... it looks like you are trying to use a mild steel mig wire and lay a bead into aluminum....... I'd get another piece of some mild steel, clean it up good with a sander or grinder and try it again.....
Then post what you have and we'll see what we can do for you.
Old August 20th, 2009, 12:46 PM   #3
blazn4dr
blazn4dr's Avatar
Looks like he is using a stick welder
blazn4dr is offline   Reply With Quote
Old August 20th, 2009, 12:48 PM   #4
firehawk
Live Action!
firehawk's Avatar
Need detail on the welder you are using.
And is that a piece of aluminum you are trying to weld on?
Old August 20th, 2009, 01:00 PM   #5
boggi
boggi's Avatar
its a old road sign i think its aluminum and the rod is 3/32" and tis a arc welder
Old August 20th, 2009, 01:08 PM   #6
forbyefore
forbyefore's Avatar
do you know anybody that can weld? I think your best bet would be to watch somebody and get some tips. Try a bit with some supervision and critique. you can read a bunch on welding but a good teacher is where it's at.
forbyefore is offline   Reply With Quote
Old August 20th, 2009, 01:09 PM   #7
jmw55018
Oh poop
jmw55018's Avatar
umm road signs be aluminum lol get some steel something like a 1/2 inch thick set your stick welder up at about 225 amps and practice laying some beeds. if its an ac welder it will be easier if its ac and dc switch it to the ac setting. you want to pull your weld with a stick welder as well. dont try to push it.
jmw55018 is offline   Reply With Quote
Old August 20th, 2009, 02:09 PM   #8
95geo
newbie
95geo's Avatar
Buy a book, read it cover to cover and then go back at it.
Old August 21st, 2009, 11:34 AM   #9
jeepnxj96
jeepnxj96's Avatar
225 amps??????????????? your not serious are you??????? best bet 3/32 or 1/8 at around 75-90 amps. start your arc like you are striking a match and keep the rod end ~1/8"-3/16" from work piece and drag backwards. watch the puddle formation, try to keep and even pace dragging and feed the rod to maintain puddle dia. with proper heat and speed, the slag will almost peel itself off the weld bead............ oh and use steel to weld to not aluminum.
Old August 21st, 2009, 12:14 PM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
225 amps......... must be an ironworker
Old August 21st, 2009, 12:33 PM   #11
redline8300
Redline8300
redline8300's Avatar
Do it the easy way, get a mig.
redline8300 is offline   Reply With Quote
Old August 23rd, 2009, 10:31 AM   #12
Flat_Black
The Dodge Guy
Flat_Black's Avatar
x2 225 amp will blow a nice hole if its your first time welding.
Old August 23rd, 2009, 10:32 AM   #13
boggi
boggi's Avatar
thanks for all the tips guys i got my floor patched with metalscrews but i will try to keep up welding after i get a nice peice of steel for a bumper after some practice thanks
Old August 23rd, 2009, 10:43 AM   #14
capone
capone's Avatar
Congrats to you for trying
capone is offline   Reply With Quote
Old August 23rd, 2009, 10:48 AM   #15
Nuggets
I fix stuff!
Nuggets's Avatar
x2. We've all been there.
Old August 23rd, 2009, 01:50 PM   #16
Brods
Welding thin sheet metal with stick is one of the harder things to do. Use the smallest rod diameter you can get and stitch weld it (basically short welds or tacks one after another with a pause in between to allow the metal to cool some so it does not melt through). Better off with a squirt gun (mig) for the thin stuff.
Welding is fun and can be rewarding, but not something to screw around with. It can hurt or kill you if you make dumb mistakes or even by doing something as seemingly harmless as cleaning the parts with brake cleaner prior to welding. http://www.brewracingframes.com/id75.htm
Read the warnings and heed the advice! http://www.lincolnelectric.com/knowl.../lenstaybl.asp
Some sources for info:
http://www.lincolnelectric.com/knowl...icles/list.asp
http://www.millerwelds.com/resources...-skills/stick/
http://www.weldingtipsandtricks.com/index.html
http://www.offroadfabnet.com/forums/index.php
Old August 23rd, 2009, 09:44 PM   #17
jmw55018
Oh poop
jmw55018's Avatar
i said to practice on 1/2 inch thick steel with it at 225 lol not on thin sheet metal.
it always easier to learn with thick steel so you dont melt it into nothingness.
and yes i used to be a production mig welder. max her out and go like hell lol
in all honesty i wouldnt really want to use a stick welder on floorboards. they are more suited to welding big dirty peices of steel outside in the mud. get yourself a mig welder.
even a cheap little wire feed with no gas and flux core will be better for floor sheets then a stick welder.
i would recomend a hobart handler 187 thow. once you get a halfway decent mig welder you will never want to touch a stick welder again.
Old August 24th, 2009, 02:46 PM   #18
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Your a fucking Retard. In fact you make Retards look smart. And he is NOT an Ironworker.
Old August 24th, 2009, 09:34 PM   #19
boggi
boggi's Avatar
thanks man
thanks for all the info dude i read alot of them, you learn alot while reading, and im goin back to dads tonight so i will start at it again with a good peice of steel
Old August 24th, 2009, 09:40 PM   #20
Exploder4x4
You're a fucking retard. ;)
Exploder4x4 is offline   Reply With Quote
Tags
welding
Page generated in 0.50360 seconds with 83 queries
