camber adjustment - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2009, 11:23 AM   #1
14muddn
Default camber adjustment
Since I bought the truck it's always had positive camber. The ball joints were bad, I thought that could be the problem so I put in new uppers and lowers and the problem is still here. I've done a lot of looking at the truck trying to play around with the upper control arms, but it sees like that adjusts caster. I'm hoping someone could help shed some light before I get too much wear on the outside of my tires.
14muddn is online now   Reply With Quote
Old August 20th, 2009, 11:37 AM   #2
traveller
traveller's Avatar
Take it to a shop with an alignment rack. If you are adjusting caster thats also were you adjust camber. If you've been messing with it you have also been adjusting toe. Make sure the cams in the upper control arm are slotted and take to someone for an alignment.
traveller is offline   Reply With Quote
Old August 20th, 2009, 11:39 AM   #3
If its never had the camber/acster adjusted then you have to remove the upper control and remove the "Knock outs". the factory sets the control arms and they are not adjustable. Once you remove the "knock outs" you can get quite a bit of adjustment out of it. The "knock outs" are in the bracket on the frame.
Page generated in 0.24658 seconds with 32 queries
