87 chevy pickup fast Idle problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2009, 08:03 PM   #1
Mall Wheeler
RIP Collin
Mall Wheeler's Avatar
Default 87 chevy pickup fast Idle problems
I have an 87 chevy pickup that is fuel injected, 4x4 auto, 350, the truck has a fast idle. does anyone know how to fix this , I was thinking about taking the fuel injection off and switching to a carb, but if it is an easy fix I would like to keep it. I have checked vacum lines and also have sprayed carb cleaner around the base and still not change......
Mall Wheeler is offline   Reply With Quote
Old August 18th, 2009, 08:54 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
This just start, or has it been coming on gradual? I was thinking the TBI base gasket was cracked or sucked in. Is the vacuum ball good? Do you hear any kind of sucking from under the dash? The heater controls use vacuum for mode changes usually.
Old August 18th, 2009, 09:17 PM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Sounds like the idle control valve on the side of the throttle body, $30.00 part.
Old August 19th, 2009, 06:26 PM   #4
Mall Wheeler
RIP Collin
just changed gasket and throttle control valve and still the same,
Old August 19th, 2009, 10:07 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
checked ignition timing? i've seen the hold downs loosen and cause the distributor to move around.
Old August 19th, 2009, 10:27 PM   #6
BigBlockBlazer
Axle breakin' 101
Throttle control valve or "idle" control valve?
Old August 19th, 2009, 10:28 PM   #7
BigBlockBlazer
Axle breakin' 101
I've had a hold down break off at the tabs, what the f---!!!
Old August 20th, 2009, 05:15 AM   #8
Mall Wheeler
RIP Collin
I thought I was changing the idle valve but in a not so bright moment I changed the throttle valve, so I will change the idle now. Check the hold down and it is tight. Thanks for the reply's I will let know know if this work in a day or so.
Page generated in 0.24876 seconds with 47 queries
