ranger trans and t case question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2009, 01:58 PM   #1
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Default ranger trans and t case question
i have a 99 2wd ranger with a 5 speed in it
trying to make it 4wd what needs to be done the the trans to accomplish this.
Old August 18th, 2009, 02:09 PM   #2
95geo
newbie
95geo's Avatar
you need to make it 4wd, duh!
www.car-part.com and get the right trans and t-case, why screw with it?
Old August 18th, 2009, 02:19 PM   #3
hosejockey4506
Visiting Admin
wondering if i can just remove the tail shaft and bolt a t case to this trans or if i need a completely different trans
tried putting a divorced case in there but no room
Old August 18th, 2009, 02:54 PM   #4
ranger98
titties
ranger98's Avatar
well hopefuly we can make the t-case i have work in there
ranger98 is offline   Reply With Quote
Old August 18th, 2009, 02:58 PM   #5
Tom
Because racecar
Tom's Avatar
You need to change the main shaft which requires disassembling the trans.
Old August 18th, 2009, 03:23 PM   #6
bj house
bj house's Avatar
x2 if it were an auto I just swapped my output shaft and removed the tailhousing, bolted 4wd tailhousing on, bolted t-case up and presto! :) The rest of the conversion was a mutha though
Old August 18th, 2009, 04:17 PM   #7
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Couple Questions to make sure (and because i'm not sure on some of them)
Is it an Edge model? (just curious)
5 speed Auto or the 5 Speed Manual?
Are you doing an SAS of the front to accomplish 4wd or Factory 4wd Ranger parts? (I know the question was about the trans, but I'm curious)
The easiest route would be to go to a junkyard and find a 4wd version of the transmission you're looking for, and get the whole assembly. Each engine has it's own unique bellhousing patern, so you need a trans out of a vehicle with the same type of engine. 4 cylinders are a bit special: 2.3L and 2.5L up to 2000 are the same, 2001 2.3L and newer are the same. They will not interchange between those years. All other patterns remain unchanged.
Old August 18th, 2009, 07:16 PM   #8
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
the main shaft will have to be changed. if you can not do the shaft swap yourself then a 4x4 trans from a yard is your best bet.
good luck finding a good 4x4 manual trans !
Old August 18th, 2009, 07:44 PM   #9
hosejockey4506
Visiting Admin
yeah its a 3 liter manual trans
Old August 19th, 2009, 05:22 AM   #10
brinker
brinker's Avatar
I have a extra 4x4 manual trans from a 92 explorer with a 4.0 if the bellhouseings are the same it would work. i just pulled the reverse gears out of it. its easy to replace them.
brinker is offline   Reply With Quote
Old August 19th, 2009, 10:30 AM   #11
boggi
wen in doubt throttle out
boggi's Avatar
Send a message via MSN to boggi
only the 2.8s, 2.9s, and 4.0s share the bell housing
you should just get another 4x4 truck, take the trans and tcase from her and put in yours, along with the front axle/drive shafts
boggi is offline   Reply With Quote
Old August 19th, 2009, 01:49 PM   #12
hosejockey4506
Visiting Admin
truck is basically done minus the cage and t case
suspension and axles are already in there.
im going to build a flipped and divorced dana 300 i think
Page generated in 0.28862 seconds with 59 queries
