F-150 Caster/camber Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2009, 02:41 AM   #1
red347lx
red347lx's Avatar
Default F-150 Caster/camber Question
Whenever I Pull In My Driveway My Tires Look Perfect And Straight Up And Down. But When I Back In My Driveway They Look Like They Are Leaning Inward At The Top Of The Tire???????????? Its A 4x4 Truck If That Helps. What Is My Problem??????ball Joints Tie Rods Maybe??? Let Me Know What You Think. Thanks
red347lx is offline   Reply With Quote
Old August 17th, 2009, 02:45 AM   #2
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Well I assume your truck has independent front suspension. This means your wheels lean while the suspension compresses and decompresses. As compared to a straight axle setup like the rear. My guess is your driveway has a bit of slope to it. So when you are backed in there is more weight on the front end, slightly compressing the suspension and causing the lean you see. If its leaning alot then something could be screwed up and we will need more info about how it drives, the year etc.
brandonjb is offline   Reply With Quote
Old August 17th, 2009, 03:09 AM   #3
MiNi Beast
MiNi Beast's Avatar
Do you have any lift or suspension mods or is it stock? Perhaps get a front end check at a shop, just a thought.
Old August 17th, 2009, 03:25 AM   #4
red347lx
red347lx's Avatar
95 f-150, 4x4 stock everything. just looking for some advise or someone who may have had the same issue.
Old August 17th, 2009, 03:34 AM   #5
MiNi Beast
MiNi Beast's Avatar
Best I could do, check this site out
96 f150 alignment problems after leveling kit - Ford F150 Forum - Community of Ford Truck Fans
Old August 17th, 2009, 10:24 AM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
this is normal on TTB (twin traction beam) ford trucks.
one of the many reasons i don't own one anymore!
Old August 17th, 2009, 10:49 AM   #7
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
All TTB's do that, it's wose with a lift-looks like it's going to puke.
Old August 17th, 2009, 11:10 AM   #8
prozak1986
prozak1986's Avatar
with the TTB or twin I beam ( however you say it ) i would say its normal because wen you park with your front end facing down a little there more weight on the nose of the truck , is there any wear on the inside of the front tires ? if not id say theres nothing to worrie about
prozak1986 is offline   Reply With Quote
Old August 17th, 2009, 01:10 PM   #9
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
normal for a ttb, if your tire s arent wearing funny dont sweat it
broncobuddha is offline   Reply With Quote
Old August 17th, 2009, 01:28 PM   #10
Its because of the steering..........
When you back up the tires fight each other and the steering wants to "walk up" the susp travel. If you look the left tie rod connects to the right side damn near center of the truck. Same concept as when you lift the ttb and do not use a drop pitman arm you get death wobble.
For the most part its normal, but having your toe out out of spec can make it appear worse.
Old August 17th, 2009, 04:31 PM   #11
red347lx
red347lx's Avatar
yeah the front tires wore towards the inside. I was told this is normal. and i was told there is something wrong with it. Guess i better get it lo ked at. thanks
Old August 23rd, 2009, 10:21 AM   #12
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
i have a lifted 96 f150 and i hate the front end on it i had it alignd 4 times and its still not right
ATOMIC_BADBOY is offline   Reply With Quote
Old September 4th, 2009, 11:27 AM   #13
radhazard1
radhazard1's Avatar
Send a message via MSN to radhazard1 Send a message via Yahoo to radhazard1
Thumbs up
Have a shop check your front end and alignment. Simple as that. Everyone has different thoughts but the first thing to do would be have a shop check it out. My 1990 F-250 with ttb always drove straight with normal tire wear. But then again I own my own shop so it should be straight.
radhazard1 is offline   Reply With Quote
Old September 4th, 2009, 11:37 AM   #14
HVYRTFT
Reed my teef
HVYRTFT's Avatar
is said shop at river road and whitehall rd?
Old September 4th, 2009, 12:24 PM   #15
That isn't his concern, backing up into a parking spot is.
Old September 4th, 2009, 06:21 PM   #16
radhazard1
radhazard1's Avatar
I know what his concern was. That was directed to the guy who said they always wear tires and the other guy that said he needed the alignment done 4 times. A good alignment that is done right or the suspension being done right, will fix that. My point is ttb does not have to wear tires and in my case it didn't, nor did I go through ball joints like people say.
Yes my shop is on the corner of Whitehall Rd & West River.
Old September 4th, 2009, 06:36 PM   #17
I totally agree, If somebody doesn't understand how a ttb works then they have no business touching one when it comes to an alignment.....I get stuck with ALL my shops TTB's and TIB's
Old September 4th, 2009, 07:07 PM   #18
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
http://superlift.com/Catalog.asp?P=1024
Superlift has this steering system to help fix the problem.
.............I have close to 200,000 mile on my ttb,...........no tire wear, but I take care of it.
Page generated in 0.40792 seconds with 78 queries
