Dakota overfueling issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2009, 09:30 AM   #1
mboies
BS MUDDERZ
mboies's Avatar
Default Dakota overfueling issue
I have a 2000 dodge dakota 4.7L, AT that has an overfueling issue. I had a programmer on it, when i took it off the the truck started running rough. I replaced the upstream O2 sensor. The local dealer put it on the scanner for me to make sure that was the only problem. It worked for about 2 or 3 weeks then it started acting up again and i replaced the o2 sensor again under warrenty. This happened 3 times total. After the 3rd the dealership then took it upon them selfs to scan the truck, then 3rd time of replacing the o2 sensor they had started pulling the P0171-1/1 FUEL SYSTEM LEAN code. I got the print out sheet with all of the possible cause of the problem and with out spending outragous amounts of money their is no easy way to find out the problem.
mboies is offline   Reply With Quote
Old August 17th, 2009, 04:51 PM   #2
mboies
BS MUDDERZ
mboies's Avatar
ttt
Old August 17th, 2009, 09:29 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
when you removed the programmer from the truck did it uninstall itself completely? i've seen some programmers not completely uninstall itself due to a low battery and cause the computer of the vehicle to crash. basically causing all sorts of problems.
Old August 18th, 2009, 05:40 AM   #4
mboies
BS MUDDERZ
mboies's Avatar
the programmer screen said that it uninstalled. we put the programmer on 2 other trucks since then also and it has not affected either one of them. What would be the best bet on fixing this problem. i have already left the battery unhooked for hours to no success
Old August 18th, 2009, 10:15 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
contact manufacturer of programmer? how did it run with the programmer?
Old August 18th, 2009, 10:32 AM   #6
Freak
Wheelin the HD
Freak's Avatar
dodges do not like power programmer, thus why it voids the warranty on them, I have heard of people having nothing but problems with magnum/hemi motors and programmers, cummins, however, will love the programmer, till you remove it, then, they fukc up like the other motors.
In other words, keep the porgramer away from your Dodge.
Old August 18th, 2009, 04:26 PM   #7
mboies
BS MUDDERZ
mboies's Avatar
the truck ran like a raped ape with it in. the only problem i had with it was watching the fuel gauge go down.
Old August 19th, 2009, 06:21 PM   #8
mboies
BS MUDDERZ
mboies's Avatar
bump
Old August 20th, 2009, 08:53 PM   #9
mboies
BS MUDDERZ
mboies's Avatar
ttt
Old August 23rd, 2009, 09:26 AM   #10
mboies
BS MUDDERZ
mboies's Avatar
ttt
Old August 24th, 2009, 06:48 PM   #11
mboies
BS MUDDERZ
mboies's Avatar
bump
Page generated in 0.41514 seconds with 56 queries
