727 making noise and won't move in drive? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2009, 07:58 PM   #1
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Default 727 making noise and won't move in drive?
not quite sure what my son did to the Dodgolet this morning but I had to tow it out of a hole and up the barn after he ran it out of gas trying to get it moving. he said it backed up under its own power but then wouldn't go forward. I drove back to it and it was wedged up on a tree I turned into a bench along the pond. I got it running long enough to hear a loud whine like a stripped sun gear. the only diagnois we did was get it running and pull it down into the Low gear and it drove forward no problem and made no noise. put it back in drive and it won't move and just whines. I dunno on this without tearing it down. anyone else run into this before?
Yetti
Old August 17th, 2009, 08:39 PM   #2
user name
keep your stick onthe ice
user name's Avatar
one of the clutch packs is probably smoked when you pull the shifter all the way to low it engages the L/R band(not normally engaged in first) and would make it move forward.
Old August 17th, 2009, 08:46 PM   #3
Marine_mike
SNSHTF
Marine_mike's Avatar
Did he get any water in it?
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old August 17th, 2009, 08:56 PM   #4
Yetti
Yetti's Avatar
why would it be whining? it doesn't whine at all in low?
Yetti
Old August 17th, 2009, 08:57 PM   #5
Yetti
Yetti's Avatar
he's not allowed to drive in the water. its got to much residue from old leaks on it. it would kill my fish.
Yetti
Old August 19th, 2009, 06:54 PM   #6
Yetti
Yetti's Avatar
well I got some more info and found out that he(my son) tried to climb a new cut in the back hill. if he had got it a little more straight up he would almost have flopped it vertically. from what I gather about the trans he smoked the forward clutch pack when it got vertical. ran the pump dry for a second or two and then "poof". when he backed down the trans was whining bad, since the trans uses a fiber filter it plugged with debrie and is now cavitating for fluid, hence the whine. its still worth $140 a ton for scrap!
Yetti
Old August 19th, 2009, 09:59 PM   #7
user name
user name's Avatar
or put a new filter in and just run manual 1 around the yard some more
Old August 20th, 2009, 04:02 AM   #8
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
X2345576 mine did that when we took it apart the 2nd gear band was seized it was almost like having a line lock cus you could tack it up and shift to first and leave hard
scramblerman72 is offline   Reply With Quote
Page generated in 0.33198 seconds with 47 queries
