2001 Silverado rear door adjustment? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2009, 08:34 PM   #1
2000XJ
NEVER ENDING PROJECT
2000XJ's Avatar
Default 2001 Silverado rear door adjustment?
My 2001 Silverado ext. cab rear door gap off. It is "sagging" which doesn't allow the front door to seal. The gap between frt and rear door at the top is o and 3/8 to 1/2 at the bottom. The door gap on frt door is uniform between fender and door. The hinges are tight, welds are good. Any advise would be helpful.
Thanks
2000XJ is offline   Reply With Quote
Old August 15th, 2009, 09:04 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like someone swung from it while open. I suggest you bend it back. if its the lower hindge caved in use a 2x4 in the door jam and just lift the door as it closes into the jam. if its a bent upper hindge then you might want to use a floor jack to lift the door with a baord spreading the load at the bottom of the door casing. just lift a bit at a time just off the jam so as you don't twist the post its mounted to.
Yetti
Old August 15th, 2009, 10:39 PM   #3
2000XJ
2000XJ's Avatar
i'll try that and let ya know - thanks
Page generated in 0.12936 seconds with 32 queries
