I need PWC help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2009, 02:30 PM   #1
unclemyke
Default I need PWC help!
I bought this ski in pieces. It's a '94/5 Polaris SL750. It needed a pto piston and a cdi. I bought everything I needed and put it back together. Took it out for a test ride and it ran pretty good for a few minutes, then started to bog and die. I though it had run out of gas, so i loaded up and headed back home.
The next day I filled up on fuel and headed back to the lake. It started right up but wouldn't go and would bog and die. It will idle "OK", but will not rev or move with the choke off. I gotta do some pretty fancy choke work to get it to move. So....back on the trailer it went. It will start and idle, but when I try to rev it out it starts spitting gas back up through the carbs and will only rev to what I would guess 3g's(?). I pulled the cover plates off the carbs and completely cleaned them out. I bypassed the on/off/reserve "switch".
I switched the cdi with another one I have....same results. I NEED HELP!
unclemyke is offline   Reply With Quote
Old August 15th, 2009, 02:45 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
float needle sticking
Old August 15th, 2009, 04:05 PM   #3
unclemyke
nope...they're nice and loose ;-)
Page generated in 0.19578 seconds with 32 queries
