CAUTION 90s Ford Cruise Control Recall - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2009, 04:11 AM   #1
CountryBoy350
CountryBoy350's Avatar
Default CAUTION 90s Ford Cruise Control Recall
If you own a 90s Ford F series truck then I would advise you take unplug the cruise control / horn connection to the steering wheel. They are known to be faulty and were recalled. My buddy's 94 F150 went up in flames today because of this problem. Its a damn shame because it was a very nice truck and I happened to have my camera with me so I recorded it. He loved the truck but only had PLPD insurance so he's screwed. And we later found out that the fuel lines melted and it was leaking gas so we're lucky it didn't blow.
http://www.ridelust.com/fault-cruise...lion-vehicles/
Video:
CountryBoy350 is offline   Reply With Quote
Old August 13th, 2009, 07:47 AM   #2
MilwaukeeF350
Dan
When we bought Ford Van I knew it have recalled due saw brake fluid puddle in cruise sensor. Went to Gorno dealer and they replace for free.
Old August 13th, 2009, 07:51 AM   #3
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Hmm... I have a 94 F250. I'll have to stop by a dealer and see if it has been done.
Old August 13th, 2009, 07:57 AM   #4
capone
capone's Avatar
That sucks. Something to think about if you just have PLPD insurance you can add fire and theft to your policy. I think on my truck it was $90.00 more every 6 months.
capone is offline   Reply With Quote
Old August 13th, 2009, 08:20 AM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
My truck has full coverage. I hope that fucker burns so I can get a better looking one.
Old August 13th, 2009, 10:20 AM   #6
Daddy Dan
SBF Nut
Daddy Dan's Avatar
If its been done to your truck, you will have a fuse in the line from the switch. Either it will be a blade fuse or a fuseable link. If not, Ford should still do it for free. If they don't, you can get a fuse holder from an auto parts and tie it in the positive wire to the sensor. A 3amp fuse will work fine.
Daddy Dan is offline   Reply With Quote
Old August 13th, 2009, 10:42 AM   #7
dirt poor
dirt poor's Avatar
Sorry about his loss. Need to check my truck as well.
dirt poor is offline   Reply With Quote
Old August 14th, 2009, 07:39 PM   #8
Never_Evil
Where did it start smoking from? Were there any warning signs other than the smoke such as something electrical not functioning?
Happy for you guys getting out in time. Sorry for the loss of the truck.
Old August 19th, 2009, 09:40 AM   #9
Never_Evil
Is there an answer to the question for everyone to know?
Old August 19th, 2009, 11:18 AM   #10
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Its the switch on the master cylinder. It basically is a pressure switch that the cruise control uses to disengage when braking. What happens is that it may leak, and the switch is fed power 24/7. If it leaks, and then shorts, it lights the brake fluid on fire.
So, it starts at the brake master cylinder and it spreads quickly from there. Its also been known to happen with trucks that have been turned off and parked for a while. It can happen at any time. It is very wise to take it to the dealership or put a fuse in like I described above. That way, it blows the fuse as soon as it shorts and it doesn't burn.
BTW, the positive wire should be red or red/white. And, if you don't use cruise or it doesn't work, you can just unplug it.
Old August 20th, 2009, 12:25 PM   #11
MichiganJeeper
id be pissed if that was in my yard :D
i feel bad for your friend.
MichiganJeeper is offline   Reply With Quote
Old August 20th, 2009, 01:13 PM   #12
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Recall 05S28 for this issue has been out for a long time. Letters were sent out to all owners with affected vehicles. Ford is still doing this recall all you have to do is call the dealership and give them your vin, they can tell you if it has been done or not.
Troll53 is offline   Reply With Quote
Old August 21st, 2009, 07:45 PM   #13
Daddy Dan
SBF Nut
Daddy Dan's Avatar
So I'm just curious, what was the bill? Fire departments don't come out for free. And what about those people's yard?
I also doubt it would have blown up. That is just a Hollywood thing. All it could have done is made a hotter and larger fire. If you've ever poured gas onto a fire, it doesn't blow up, it goes "WOOF".
Page generated in 0.29448 seconds with 63 queries
