1999 Lincoln Towncar, codes P0155 and P1155 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 12th, 2009, 09:14 PM   #1
Bones
Bones's Avatar
Default 1999 Lincoln Towncar, codes P0155 and P1155
P0155 - heated oxy sensor bank 02 sensor 1 circuit fault
P1151 - lack of oxy switches bank 02 sensor 1
This is my neighbors vehicle, trying to help them out. They just bought it and this started right away. There is a hesitation in the engine from 35-40 mph while in OD, very low RPMs. I can't get it to do it in any other speeds.
cleaned the MAF, didnt do a thing.
Obvious explanation would be a bad oxy sensor, but I am reading a lot of things online that say people replaced the sensor and nothing changes. I don't really want to waste their money if that isn't it ($55). I would pin in out first, but it is a PITA to get to the harness there while the vehicle is running. I found a fuse that is labeled for "oxy sensors, transmission solenoids, etc etc" and it is fine.
I'm thinking swap the oxy sensor and hope, then start tracing wires. Usually (with my experiances) when oxy sensors fail they give rcih or lean codes, which are completely different than the circuit fault this is throwing.
any help, thanks.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 12th, 2009, 09:20 PM   #2
Bishop
Bishop's Avatar
oxy sensors really shouldn't make a car run bad. if it has a fault it will go into default mode and run fine unless you have other issues that need to be fixed. in that case it may say its bad so you replace it and still have a problem.
in other works, if everything is working you can unplug the o2 and have no performance issues.
have you looked at the plugs?
also try unpluging the maf and see if it goes away. it could be bad and just not from being dirty, so cleaning it wont help.
Old August 12th, 2009, 09:26 PM   #3
Bones
Bones's Avatar
nope, I would expect a misfire code for the hesitation it is giving I think... maybe not though.
The car runs great other than the hesitation at 35-40 mph and it only happens 1 in 10 times or so.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 12th, 2009, 09:29 PM   #4
Bishop
Bishop's Avatar
yeah but its a quick check. just because there is no codes doesn't mean anything.
Old August 12th, 2009, 09:32 PM   #5
Bones
Bones's Avatar
I'll look into the plugs
also, it has what looks like a new fuel filter.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 12th, 2009, 09:46 PM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
check all the vacuum lines!
mostly the pcv T and other rubber connections.
i am willing to bet this is the problem
Old August 13th, 2009, 06:01 AM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
any help, thanks.
1. Check fuses for the O2 sensors with a DVOM - sometimes what looks fine isn't
2. Check for 12V @ the heater pin
3. Check your kams and see which way they're off in the area the hesitation is
4. What is B1 doing, and how are the kams for that bank?
5. Also - I just thought about it - when you get the hesitation, what is lockup doing?
I'm spent.
@clarkstoncracker
Old August 13th, 2009, 04:41 PM   #8
Bones
Bones's Avatar
I confirmed 12V on the 2 power wires. Then I replaced the HEGO, no change.
ugh
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 13th, 2009, 11:13 PM   #9
Yota Bill
swap the upstream Ho2s and run the car, without clearing the codes..see if it then sets the same codes for the other bank, if not, the O2 is not the problem.
*edit* just saw you already tried the "throw money at it" procedure first
Old August 13th, 2009, 11:16 PM   #10
Yota Bill
I'm thinking the key lies in this statement...it may be more of a trans issue then an engine issue..check the condition of the trans oil, and watch the trans with a scanner while test driving...
Old August 14th, 2009, 05:16 AM   #11
frdboy
frdboy's Avatar
Sounds like a Secondary miss to me, probably happens just after the converter locks up and you ease into throttle. If you can get Mode 6 data from your scanner you can probably ID what cyl. is missing. Is this a coil on plug car?
Old August 14th, 2009, 07:58 AM   #12
Bones
Bones's Avatar
it is coil on plug. How hard are the plugs to change on the 4.6L? they look like the coil on plug sits directly under the fuel rail. Do I have to remove the fuel rail to change em?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 14th, 2009, 08:17 AM   #13
frdboy
frdboy's Avatar
You can get the coils out without moving the rail, it's not a bad job at all. You may have a coil starting to fail though and replacing just plugs may not fix it. If the boots on the coils are really soft and expanded you can buy those separate from the coils, Auto value or napa should carry them.
Old August 14th, 2009, 08:32 AM   #14
Bones
Bones's Avatar
the owner already gave me the green light for doing plugs, so we'll try that next.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 16th, 2009, 05:54 PM   #15
Bones
Bones's Avatar
just did plugs and fixed an exhaust leak, it doesn't look like any change.
Is there any way to test coils?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 16th, 2009, 08:53 PM   #16
Bones
Bones's Avatar
oh, and I think it has high idle
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 24th, 2009, 10:14 PM   #17
Bones
Bones's Avatar
replaced the IAC, nothing new
hate this car
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 24th, 2009, 10:19 PM   #18
frdboy
frdboy's Avatar
Still setting the same codes?
Page generated in 0.55488 seconds with 77 queries
