? about o2 sensor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 12th, 2009, 10:10 PM   #1
hondadirtracer
Skymaster
hondadirtracer's Avatar
Default ? about o2 sensor
I have a '93 c1500 with the 4.3 tbi in it, and my o2 sensor bung broke off of my y-pipe. Would I be able to patch the hole in the y-pipe and just run it without an o2 sensor, or do you guys suggest that I get a new bung and put the o2 sensor back in. If I don't have to put it back in, can I unplug it, or should I just leave it hang there? And will it throw an ses light? and if so, would I be able to get it cleared and not have it come back?
hondadirtracer is offline   Reply With Quote
Old August 12th, 2009, 11:06 PM   #2
traveller
traveller's Avatar
If ya plan on keeping the truck fix it if not don't worry. Check engine light will come on and no you won't be able to clear it and you'll probable lose gas mileage.
traveller is offline   Reply With Quote
Old August 12th, 2009, 11:16 PM   #3
hondadirtracer
Skymaster
i plan on keeping the truck for about 2 years
Old August 13th, 2009, 12:06 AM   #4
scottie
Eye candy
scottie's Avatar
fix it
Old August 13th, 2009, 12:14 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you need that sensor for engine control. fix or replace it. if it was the O2 sensor after the cat then you could eliminate that sensor without worry.
Old August 13th, 2009, 06:11 PM   #6
Wehan
Wehan's Avatar
Fix it or you will wash the cylinders down with gas, causing premature engine failure.
Wehan is offline   Reply With Quote
Old August 13th, 2009, 08:13 PM   #7
jbsjunk
Little Member
jbsjunk's Avatar
These.
Old August 14th, 2009, 09:03 PM   #8
Disturban
Disturban's Avatar
Any exhaust shop has new bungs they can weld in for you, it will cost you about $20 to $30, if they want more find another shop!
Old August 14th, 2009, 11:11 PM   #9
nathanthegreat
not really
nathanthegreat's Avatar
a shop cant afford to drive that thing in the door for 30$. figure around 60$ at least.
nathanthegreat is offline   Reply With Quote
Old August 14th, 2009, 11:16 PM   #10
hondadirtracer
Skymaster
It is $75 for a new y-pipe with an o2 bung on it. I am taking it to my uncles tomorrow and we are going to weld a washer over the hole and weld a nut that the o2 sensor will fit in over the washer.
Old August 14th, 2009, 11:17 PM   #11
jbsjunk
Little Member
jbsjunk's Avatar
They would probably charge $10-20 just for the bung if they had them.
Page generated in 0.24758 seconds with 56 queries
