Anyone running a Lq4 or lq9 in thier jeep? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2009, 09:31 PM   #21
somer1
You Get the Big One
somer1's Avatar
99 and some 2000's are all Iron, A freind of mine run's a 99' all iron 6.0l in his truggy.
somer1 is offline   Reply With Quote
Old August 13th, 2009, 09:32 PM   #22
95geo
newbie
95geo's Avatar
mine will be DBW unless I have a problem with it. I will be making a starter tune to make it run but for the final tune I will be modifying the harness myself and having vector motorsports do the tune on their chassis dyno.
Jims performance is great for a standard tune for something like a stock engine. I will have an after market cam and cam phasing so it needs a lot of fine tuning. a tune and dyno time from vector is about 500 as where jims charges about 400 for a tune and a harness that is plug and play.
Old August 13th, 2009, 09:35 PM   #23
95geo
newbie
95geo's Avatar
Don't early LQ4s have iron heads, and later ones are Aluminum?
I havent heard that... never knew of any gen 3 heads that are iron, as far as I know there are all aluminum heads.
maybe you are thinking of the 99 3/4 tons that were still the old style body with the 5.7's?
Old August 13th, 2009, 09:36 PM   #24
Corvette oil pan:
good resource here on oil pans:
http://ls1tech.com/forums/conversion...-oil-pans.html
Old August 13th, 2009, 09:36 PM   #25
95geo
newbie
95geo's Avatar
I'm going to check for sure tomorrow, if you ever run across one, stay away!
Old August 13th, 2009, 09:38 PM   #26
95geo
newbie
95geo's Avatar
Corvette oil pan:
that is a C5 Z06 pan, i.e. "batwing" jim runs a c6 pan which is much more compact, the downside..... they changed the test so the new design would pass
I have a C6 vette pan for sale FYI
Old August 13th, 2009, 09:39 PM   #27
I don't know how much I trust that LSX book that I got that info from, it has lots of quotes from your Dad in it....
Old August 13th, 2009, 09:49 PM   #28
dline
dline's Avatar
turbos exhaust....???
dline is offline   Reply With Quote
Old August 13th, 2009, 09:57 PM   #29
TomH
Oftentimes an idiot
TomH's Avatar
I have an LQ9 in the WTF-J. It sits in front of an 4L65e and an Atlas TC. I put in the GMPP "Hot Cam" and love it.
I stayed with the truck intake/pan and have plenty of room under the hood and clearance (See the third pix with the crossover and note the location of the front diff/drive shaft. The oil pan is not the low point by any means.)
TomH is offline   Reply With Quote
Old August 13th, 2009, 10:07 PM   #30
95geo
newbie
95geo's Avatar
It says they exist but I havent seen one yet... I didnt think they released the 6.0L until 2000... gotta do more snooping around.
Old August 13th, 2009, 10:07 PM   #31
somer1
You Get the Big One
somer1's Avatar
what did you do about the speed sensors for the transfer case? Pics look awsome. Two into one exhaust? Transfer case adapter?
Old August 13th, 2009, 10:23 PM   #32
TomH
Oftentimes an idiot
TomH's Avatar
The VSS is in a housing between the trans and the T/C. It works, but in low range the speedo goes nuts. (You can see the VSS housing in this pic.)
Yup, single exhaust. 2.5" collectors into a 3" single system. I put a bung for a wide band in the root of the Y pipe where it transitions to 3".
Old August 13th, 2009, 10:27 PM   #33
somer1
You Get the Big One
somer1's Avatar
Did you put the o2 bung in place of the two that are tipical in a swap or are you running three for tuning reasons?
Old August 13th, 2009, 10:29 PM   #34
somer1
You Get the Big One
somer1's Avatar
Also did you have to run an adapter for the atlas? And what bolt patern was on the back of the trans, 6 bolt hex with a 27 spline output? Was the 4l65e was the stock truck tranny that came with your engine
Old August 13th, 2009, 10:33 PM   #35
TomH
Oftentimes an idiot
TomH's Avatar
Did you put the o2 bung in place of the two that are typical in a swap or are you running three for tuning reasons?
Three. (Two pre-cat and one WB. The WB isn't in yet; that will be a later upgrade.)
Yes, the Atlas was the six bolt hex pattern.
The powertrain came from Schram and was out of an '06 Escalade w/500mi. It included the trans, and was a great way to buy all the pieces and parts as it included the ECM, DBW TAC, starter, alt, harnesses, etc.
Old August 13th, 2009, 10:34 PM   #36
somer1
You Get the Big One
somer1's Avatar
I'm sorry if I'm bothering you with all the questions but your the first person that I've talked with that has the set up I'm after. Headers?
Old August 13th, 2009, 10:35 PM   #37
somer1
You Get the Big One
somer1's Avatar
Is your rig operational if so what do you think of the power output?
Old August 13th, 2009, 10:40 PM   #38
TomH
Oftentimes an idiot
TomH's Avatar
Love it. Lots of grunt and it winds up real quick. The lope of the cam sounds good too.
Old August 13th, 2009, 10:43 PM   #39
somer1
You Get the Big One
somer1's Avatar
Lope of the cam? Did you do head work? On the motor .
Old August 13th, 2009, 10:47 PM   #40
somer1
You Get the Big One
somer1's Avatar
Also if don't mind me askin what did you give for the package? Schram had a complete 5.3l drive train for 3000.00 but I'm really leaning twards the 6.0l. It's what I really want and dont' want to be disapointed with the 5.3l>
Page generated in 0.42269 seconds with 83 queries
