Anyone running a Lq4 or lq9 in thier jeep? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 12th, 2009, 08:10 PM   #1
somer1
You Get the Big One
somer1's Avatar
Default Anyone running a Lq4 or lq9 in thier jeep?
Just was curios what you thought of the power and what kind of driveline your running. If you made a harness or orderd one? If the 6.0l is that much better than an LS1 or a 5.3l? My friend has a 5.3l in his yj that he rebuilt and changed to Carb with a heathy cam, it runs good up top but not really impressed with the off idle respounce. For reference I run 38's with 60's front and rear (78' Ford w/4.88's) and plan on using a np231c hd and a 4l60e (wide chain) with a Tera-Flex super short eliminator as I allready T-case and it will bolt right up to the 4l60e, as far as I know. Any info would be great. Also did you do it your self or have someone else do it?
Thanks.
somer1 is offline   Reply With Quote
Old August 12th, 2009, 11:59 PM   #2
Old August 13th, 2009, 12:01 AM   #3
A 'healthy' cam, though could really hurt the low end ona small motor like a 5.3. I know the LS6 cams are popular as a cheap HP adder, but they cut out a lot of tq below 3000, according to the side by side dyno plots I've seen. Likewise, the factory intake is designed for low end torque. So he's probably lost a good 50+ft-lbs down there in the crawling ranges, which would put it not all that much above a 4.0...
The LS1 woudl be ~90 lbs lighter, due to the aluminum block, if it matters to you. Although aluminum block 5.3s (L33s among other), and 6.0s (LS2) exist as well.
Old August 13th, 2009, 12:20 AM   #4
somer1
You Get the Big One
somer1's Avatar
Well I realy want an lq9 (6.0l) but have been thinking about the 5.3 for the money and the fact that a 5.3l came with a 4l60e and would'nt require any harness mods. I was also thinking the Ls1 as it to came infront of a 4l6oe (2wd would have to change output shaft). But I'm woundering if it's got anything down low such as the truck engines. price wise the ls1 has come down quite a bit, But I've heard that you need to switch the oil pan to a rear sump for starvation reasons.
Old August 13th, 2009, 05:19 AM   #5
I have an 03 6.0l out of an Escalade. That means cast block and aluminum heads. I used the factory harness & sent it out to be paired down for what I didn't want and at the same time had the ECM reprogrammed.
The rest of my drivetrain is a T350, stock 231 (yeah, I know) 4.88's running 39.5's. The motor makes good power pretty much throughout & don't have much to complain about. I can't give any input compared to a 5.3l.
Oh, you mentioned oil pan. I had to change to the corvette oil pan because the truck pan hangs way down.
Old August 13th, 2009, 07:33 AM   #6
Batwing pan? I hate how they put cast aluminum oil pans the truck engines..
Old August 13th, 2009, 08:02 AM   #7
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I am doing a build with a 5.3 (6.0 would be great, but $$$). I think you will be happy either way. The 5.3 that your friend has probably lost alot by going carb., and big cam. All of the people I have talked to say the 5.3 works great and even better with some ecm tuning.
Keep us posted with what you decide.
RIP FULLSIZE4LIFE
Old August 13th, 2009, 09:57 AM   #8
Yeah, eliminate the torque management and low end response is better.
Old August 13th, 2009, 10:05 AM   #9
95geo
newbie
95geo's Avatar
anyone who puts a carb on one of these engines is retarded. properly tuned fuel injection will make a carb'd engine look like a gen 1 POS in any condition. it's people who dont know any better that put carbs on them and think they are doing some good.
if you want a lot of potential then go with the 6.0L, if you want up to 400hp then a 5.3L is a good choice. a cam that sounds cool at idle is bad for low end performance. if he were to put an adjustable cam gear on it he could advance it and get some of the low end back but he's already screwed it up with that carb.
I have a 6.2L L92 and I turned it into an LS3 be removing the cam phasing. I did some research and for a couple dollars more I can put the cam phasing back on and get more low end and top end than a fixed cam. a fixed cam engine takes the low end torque and turns that into horsepower on top when you put in an aggressive cam, a stock cam will keep the low end but you lose your peak HP numbers and get a flatter power curve. Needles to say I'm swapping to VVT and going with an aftermarket cam. 530hp with more torque on the bottom end than a stock engine.
the truck intake flows better than the car intake, keep it on if you can and dont go too crazy with a cam, less is more when you arent operating in a 1000 rpm window.
Old August 13th, 2009, 11:33 AM   #10
dline
dline's Avatar
carburetors suck!
dline is offline   Reply With Quote
Old August 13th, 2009, 11:45 AM   #11
Originally Posted by dline View Post
carburetors suck!
Superchargers blow.
Old August 13th, 2009, 01:11 PM   #12
95geo
newbie
95geo's Avatar
I guess turbos blow too, huh?
speaking of which, I have a pipe dream of turboing my trailblazer. it could be fun but I'm torn between a custom turbo setup, the easy-to-do magna charger or doing the L92 goodies and staying N/A. I cant wait until my lift of projects gets small enough to take on another one!
Old August 13th, 2009, 04:58 PM   #13
somer1
You Get the Big One
somer1's Avatar
Thank you for your responces. Whiterino how do you like the 4.88's and 231, also did you run the corvette oil pan so that you could keep the truck intake. I ve heard alot of people say that the truck intake is better for torque than any other.
Any opinions on the hole Lq9 vs Lq4, I know the differences between the two engines but for a jeep is the Lq9 that much better? Opinions?
Old August 13th, 2009, 05:00 PM   #14
somer1
You Get the Big One
somer1's Avatar
95geo what are running in your set as far as trans and transfer, Rig?
Old August 13th, 2009, 06:12 PM   #15
yeah, couldn't decide which lame comment to make..
Oh, looked at the dyno charts in my book, its about a 25 ft-lb loss at 2500 rpm to put an LS6 cam in a 5.3, but adds about 40 hp above 5000rpm.
Old August 13th, 2009, 08:26 PM   #16
Haggar, not sure what you mean by batwing pan. The pan that came off was aluminum as was the one that went on. They are totally interchangeable, just the corvette one is not as deep. I think it changes is from an 8 quart capacity to 5. I also changed the baffle splash plate inside although I don't think I actually needed to. The corvette oil pan had nothing to do with the truck intake. There's no relationship there. I did it purely to keep the pan from getting smashed on a rock.
RE the 231 and 4.88's, the ratio is pretty good for general low range wheeling. With my current tire size, it's a damn good hill climber in low range but is a little too aggressive on rocks & stuff and there are times I wish I was closer to 4:1 instead of the 2.7:1. A new T-case is in the plans for the future. I have previously cracked a couple 231 cases but I beefed up the current case & haven't broken it since. I had also broken the front output shaft but ever since I went to a 2 pc carrier style front drive shaft I haven't had a problem. My theory is that with the shaft coming straight forward to the carrier bearing that I'm not putting any side load on it which helps it to survive. I'm totally aware that it's a weak link which is why I carry a complete spare T-case in my trailer.
BTW, if you get a new enough engine that has the throttle by wire, make sure you get the pedal, wiring harness and module from the same donor vehicle. Ask me how I know.
Old August 13th, 2009, 09:14 PM   #17
somer1
You Get the Big One
somer1's Avatar
Yeah I know the 231 isn't the best t case for crawlin thats why I wanted to go with a four speed trans so I can ge a lower first gear. Pertaining to the intake, I've heard of people having trouble with hood clearence because of the rather tall truck intake. As per the throtle buy pedal do you find it touchy off road?
Old August 13th, 2009, 09:18 PM   #18
95geo
newbie
95geo's Avatar
the only difference between a lq4 and lq9 is some compression and about 30hp... most of that can be accounted for with a tune because one compressions point alone is good for 4hp IIRC, it's what you do with the higher compression is where one shines over the other. IE, higher octane fuel enables you to advance the timing more and timing is power. either engine will get you well over 400hp with the right mods and tune.
Mine is a 2500 pound paper weight right now but I have a th400 and 3.8:1 atlas with 4.88's and 37's. when it moves on it's own I'm pretty sure I have the gearing nailed for the power. I do plan to swap in a 4l60,65 or 70 in place of the 400 and at that time I'll probably do a 4 speed atlas at the same time for no real reason other than I want more gears.
Old August 13th, 2009, 09:23 PM   #19
somer1
You Get the Big One
somer1's Avatar
So are you running a throtle by wire on yours or did you change it to cable also who is doing your guys' tunning? Harness mods?
Old August 13th, 2009, 09:28 PM   #20
Don't early LQ4s have iron heads, and later ones are Aluminum?
Page generated in 0.54786 seconds with 83 queries
