Need help with broken spark plug - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2009, 07:57 PM   #1
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
Default Need help with broken spark plug
I've never had a plug do this before. This thing broke like a light bulb that pulled out of the socket in the fixture. Has anyone ever had this happen to you & what did you do to get it out of the head.
Mijeeper CJ 7 is offline   Reply With Quote
Old August 11th, 2009, 08:01 PM   #2
Duramax04
Duramax04's Avatar
I had it happen in an S-10 once. Luckily, the Blue-Point/Snap-on easy-out set has a size that just fits in the broken part of the plug. Looks like you can get to it okay, so shouldn't be too bad if you know somebody who has a set.
I think it's just a matter of the plug rusting out & getting thinner in that spot.
Good luck!
Duramax04 is offline   Reply With Quote
Old August 11th, 2009, 08:04 PM   #3
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Hard to tell from that pic but did it leave only the thread behind? Looks like you can see rite into the head.
brandonjb is offline   Reply With Quote
Old August 11th, 2009, 08:04 PM   #4
Mijeeper CJ 7
thanks, I call a few friends & see what I can come up with
Old August 11th, 2009, 09:05 PM   #5
BlooMule
Old School
BlooMule's Avatar
Soak the busted part with PB blaster before using the extractor.
-rw-rw-rw
BlooMule is online now   Reply With Quote
Old August 11th, 2009, 09:10 PM   #6
Renegade II
Coil springs are for pens
Renegade II's Avatar
Did the ground electrode break off into the cyl? If so, be sure to fish that out before start up.
Old August 11th, 2009, 09:34 PM   #7
Mijeeper CJ 7
yes, just the lower half of the plug.
Old August 11th, 2009, 09:34 PM   #8
Mijeeper CJ 7
Yep, done that
Old August 12th, 2009, 12:33 AM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Big easy out should get it.
JcrOffroad
Zoom Zoom!
Old August 13th, 2009, 10:27 AM   #10
Mijeeper CJ 7
Easy out worked. Thanks for the help
Page generated in 0.31594 seconds with 53 queries
