timing chain - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2009, 11:51 PM   #1
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Default timing chain
My question is what are the symptoms of a timing chain that is loose, i've got a 79 chevy 350 and it just seems like i cannot get the thing timmed correctly. i hooked a vaccum gauge up to the carb and the thing goes mad (told thats how you can tell), tell me this is correct. It runs like it has a lack of power almost like it has a dead cylinder at an idle, but when i get on her she seems to fire on all eight. Would a timing chain cause these problems???
84ChevyMuscle is offline   Reply With Quote
Old August 11th, 2009, 01:18 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
usually a bad timing chain will cause erratic timing. this can be checked with a timing light. rev the engine to 2000 rpm and hold it. look at the timing marks and see if they jump around. chances are good if they jump around the chain is loose. i've seen some so loose they hit the cover and make a knocking sound. person pulled the engine thinking it was blown only to find that.
Old August 11th, 2009, 11:15 PM   #3
84ChevyMuscle
BigBoysNeedBigToys
thanks kodiak 450r, ill have to break out the timing and try that, im pretty sure its loose, now would my vaccum like i said be erratic also or am i wrong
Old August 12th, 2009, 10:28 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yes that can also be a symptom. i forgot about that in my first post. thats caused by the cam timing jumping around.
Page generated in 0.24237 seconds with 35 queries
