engine block painting ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2009, 12:59 PM   #1
roll-bar Bob
roll-bar Bob's Avatar
Default engine block painting ???
after hours, with a wire brush, wd40, and break cleaner I think, I am ready to paint my engine block. the block is soaked down with wd40 right now but when I get ready to paint it I was planning on washing it down with break cleaner to cut the oil on it then giving a good scrub with Mineral Spirits, or paint thinner. befor I hit it with paint.
What have you found to work the best
Old August 10th, 2009, 01:10 PM   #2
68Scout
'68 Scout ~rebuilding
68Scout's Avatar
Have it hot tanked and bead blasted. Just had that done to my scout motor and it turned out awesome.
[IMG][/IMG]
[IMG][/IMG]
68Scout is offline   Reply With Quote
Old August 10th, 2009, 01:17 PM   #3
Broncoholic
Guest
Posts: n/a
2x Need to get the oil out of the casting with heat. You can use MAPP gas & bake the surface after you use the brake clean, just burn all area's that are to be painted. use a high temp 1000 degree primer & 2 coats of hi temp epoxy...
Old August 10th, 2009, 01:22 PM   #4
roll-bar Bob
what did that cost
mine looks like the top PIC right now with a coat of wd40 over it
I will bet yours was much MUCH easier then the way I went about it
Old August 11th, 2009, 06:25 PM   #5
68Scout
68Scout's Avatar
I think it was like $100 total for hot tanking and blasting
Page generated in 0.26239 seconds with 38 queries
