One pc; 3 monitors. How? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2009, 12:08 PM   #1
mpwal099
Stick it up your ass
mpwal099's Avatar
Default One pc; 3 monitors. How?
Please school me on how to run three monitors off of one pc please. I am sure it is pretty simple hardware wise, but what I need to display is three different screens from one program (powerpoint). Is this doable and how? Thanks much!
mpwal099 is offline   Reply With Quote
Old August 10th, 2009, 12:10 PM   #2
Broncoholic
Guest
Posts: n/a
Just go 2 , 24" ones & have 4 windows open, That is what I do...works great.
Old August 10th, 2009, 12:11 PM   #3
AGoodBuzz
The other option is to pick up a couple of dual monitor PCI cards and plug them in and you can go up to 4.
AGoodBuzz is offline   Reply With Quote
Old August 10th, 2009, 12:20 PM   #4
AGoodBuzz
I checked my goodie box and have 1 that I no longer need along with the Molex splitter cable. Don't have any drivers for it though, but you can download those from Dell. It's a Dell dual monitor PCI card. Part number 102A9240221. You can have it for free if you want. Let me know: (734) 560-7226. Dennis
Old August 10th, 2009, 12:22 PM   #5
mpwal099
mpwal099's Avatar
I need a minimum of three. This is for a display.
I figured it would be easy with just the PCI cards. Any special requirements for the desktop then?
Also can I display 3 different slides from powerpoint on the 3 different monitors?
Old August 10th, 2009, 12:43 PM   #6
chuckhubbert
chuckhubbert's Avatar
Not by itself. Check this out: Powershow
chuckhubbert is offline   Reply With Quote
Old August 10th, 2009, 12:44 PM   #7
AGoodBuzz
Yes. Basically you're just extending your Windows desktop. If you right-click on your Windows Desktop, then go to Properties, then go to the Setting tab, you'll see where you can extend your desktop on to an additonal monitor. If you're already running a video card in a ddition to the onboard video of most motherboards you can sometimes get them both to feed monitors, then add 1 dual monitor PC card and you can now run 4.
Edit: Now that I think about it, you may not be able to run 3 slides from the same PP file because when you change one you change them all, and I don't think you can have 3 instances running simultaneously like you can Explorer and such.... Hmmmm. The above would be to allow you to work with differnt files in the same application all at the ssame time on different moniteors, AND drag them from monitor to monitor. I do it all the time in Excel.
Old August 10th, 2009, 12:56 PM   #8
mpwal099
mpwal099's Avatar
So... new PC needs on board video, video card, and then a dual monitor PCI card. correct?
Old August 10th, 2009, 01:00 PM   #9
AGoodBuzz
Well, as long as you can go into your CMOS and set it up to feed wideo to on-board and card at the same time. Not all motherboards allow this (some are either/or). My old Dell did it, as well as my old homebuilt. My new homebuilt I don't know because I don't need that feature anymore.
Old August 10th, 2009, 01:20 PM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
YOu can also look for an SLI motherboard and pick up two nvidia 8400 pci cards....
http://www.newegg.com/Product/Produc...82E16814150355
http://www.newegg.com/Product/Produc...2E16813131232R
@clarkstoncracker
Old August 10th, 2009, 01:24 PM   #11
AGoodBuzz
So would he then use both video outputs on each card and just adapt the cables as needed?
Old August 10th, 2009, 01:35 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Yes - I think that would work. I could try when I got home, but I don't have three monitors!
@clarkstoncracker
Old August 10th, 2009, 01:40 PM   #13
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
SLI does not support multiple monitors. Not sure why, but the only way you can use two monitors on an SLI setup is to turn the SLI support off when you want to have two monitors on.
Old August 10th, 2009, 01:42 PM   #14
AGoodBuzz
If you have two monitors you could just verify output from both ports on the one card. If that works he should be able to double up and run 4 monitors.
I wonder if he would still have a problem with the program though. In PP I think you can only open 1 slideshow at a time, so when he advances the frame it advances and that's it. The problem is that he wants seperate frames open at the same time, then drag each to a different monitor. I don't think he can open the same file 3 times. What he COULD do maybe is create 3 copies of the file and append the name, then open each copy in each monitor and advance them seperately....?
Old August 10th, 2009, 01:47 PM   #15
rubicon
you need 2 video cards software set can be kind of tricky. We run 6 monitors off one PC at work took IS about a week to get all the bugs worked out.
easiest way we found was to go with a dual out dual DVI card and split the signals to multiple outputs
rubicon is offline   Reply With Quote
Old August 10th, 2009, 01:48 PM   #16
schweeb
spelling nazi
schweeb's Avatar
going with an SLI based solution is kinda overkill, unless you're playing some heavy duty games (and even then I've heard SLI isn't anywhere near as great as advertised, if at all useful).
You just need your onboard, and then either 2 separate vidcards, or 1 dual port vidcard. Doesn't matter if it's PCI, PCI Express, etc... as long as you have a free slot.
Being able to do things in a single app across multiple monitors does require the app to have some extra smarts, usually.
schweeb is offline   Reply With Quote
Old August 10th, 2009, 02:25 PM   #17
mpwal099
mpwal099's Avatar
I think Chuckhubbert answered that issue already. I will test that out later.
Now a new issue on my end. Just hooked up my laptop to my tv. The tv display is shifted to the left. How do I remedy that?
Old August 10th, 2009, 02:29 PM   #18
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The SLI mobo is just to be able to mount two video cards - I should have clarified that. Running them together in SLI was not what I originally meant. :)
@clarkstoncracker
Old August 10th, 2009, 02:31 PM   #19
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I can certainly run two monitors - one analog and one digital - from one card.
@clarkstoncracker
Old August 10th, 2009, 02:31 PM   #20
Sandals
Fucking Zen as Shit
Sandals's Avatar
google matrox Triplehead2go
Page generated in 0.48293 seconds with 82 queries
