Trailer winches ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2006, 01:08 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Trailer winches ??
What do you recomend.. I was reading over on pirate about them and wanted some opiniona from you.. i saw a 2k unit at Harbor Freight last night for 60 bux and thought about it.. I figure use a block and double line pull it would work...
Any thoughts on this unit. or any recomendations on others without breaking the bank..
Old June 23rd, 2006, 01:39 PM   #2
I'd imagine it would work..
I still am using my old ratchet style hand winch, which has been enough power for anything i put onto the trailer so far.
Just watch to not overheat/burn out the motor, that would be my guess to the weak link.
Old June 23rd, 2006, 02:45 PM   #3
Bones
Bones's Avatar
I would go at least 4K... just wait until you bend a tie rod so you are toe-in or have ac aliper seize or have flat tires and have to pull the rig up the ramps with the wheels locked....
A 2K would be fine if the rig had 30psi in the tires and rolled freely, but then you wouldn't need the winch....
EDIT- a problem with the 2K winch is that the spool is only long enough for 50' of wire that is only rated at 2K lbs. Put a snatch block on it and your wire is only good for 4K (kind of) and is only 25' long
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 24th, 2006, 01:00 AM   #4
Mclovin
"The Situation"
Mclovin's Avatar
trailer is only 18ft and the price is right so i think i may go with that unit.... once i get some dough ill upgrade...
Page generated in 0.24023 seconds with 35 queries
