88 gmc sas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2009, 09:21 PM   #1
Biggreen89
mr. yoder
Biggreen89's Avatar
Default 88 gmc sas
traded my 91 3/4 ton with a 3inch body lift for this 88 gmc 1500 sas 10 inch suspension and 4inch body rear disc conversion and a stock 350 for now dana 44 front and rear
ID:	47548   Click image for larger version
ID:	47549   Click image for larger version
ID:	47550   Click image for larger version
ID:	47551   Click image for larger version
ID:	47553   Click image for larger version
ID:	47554   Click image for larger version
Biggreen89 is offline   Reply With Quote
Old August 10th, 2009, 06:43 PM   #2
badazzchevy
go big or go home
badazzchevy's Avatar
pics or it didn't happen!!!!
badazzchevy is offline   Reply With Quote
Old August 10th, 2009, 06:44 PM   #3
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
x2 lol
Sounds like a big truck.
JohnL is offline   Reply With Quote
Old August 10th, 2009, 07:03 PM   #4
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
get them pics son!
Old August 11th, 2009, 10:20 PM   #5
Biggreen89
mr. yoder
Biggreen89's Avatar
Default the new dd/ww
finally
Old August 11th, 2009, 10:22 PM   #6
boggin-machine
boggin-machine's Avatar
can you make the pics smaller please
Old August 11th, 2009, 10:31 PM   #7
Biggreen89
mr. yoder
Biggreen89's Avatar
trying to get it ready for labor day weekend need to figure how im going to mount the shocks add some go fast stuff to the motor build a rear bumper and it needs a fuel pump any suggestions would be great
Old August 11th, 2009, 11:21 PM   #8
Biggreen89
mr. yoder
Biggreen89's Avatar
got the pics to work
Old August 11th, 2009, 11:32 PM   #9
boggin-machine
holly blue label fuel pump if its for a cell.
Old August 11th, 2009, 11:45 PM   #10
Biggreen89
mr. yoder
Biggreen89's Avatar
it has the stock tank in it now wasn't sure if i wanted to go to a cell or not
Old August 11th, 2009, 11:50 PM   #11
Ford forever
Bought another jeep
not a fan of the leaf front end i like the coils spring radius arm set up
it looks cleaner, and works great.. also interesting tcase set up???
Ford forever is offline   Reply With Quote
Old August 11th, 2009, 11:54 PM   #12
Biggreen89
mr. yoder
Biggreen89's Avatar
i prefer the leafs personally but the tcase was in it when i got it im not sure what case it is but the axle dosn't have lockouts so its in 4 wheel all the time
Old August 12th, 2009, 02:17 AM   #13
wave_crusher
I'll Direc your TV
prolly a np 205 on the tcase, i'd be switching that hunk-o-junk out, 208's are a lot better
Nice looking project though, looks like a hell of a fun toy
Old August 12th, 2009, 02:35 AM   #14
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
wat?
The 205 has a bulletproof case, all gear internals, and a fixed yoke. The 208 has an aluminum case, chain driven, and a slip yoke. But it has lower gearing. Which means a high power bogger will probably blow up a 208, and I'm sure he'll be working toward getting some horsepower out of it. Lower gearing is not neccessarily required for a bogger. Being heavy is its only downside of the 205. Other than that, I'd say the 205 is better for his application.
Old August 12th, 2009, 05:01 AM   #15
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
That would be a 203 case and they are junk unless you get a 205 and use them both to make a doubler then that would be nice set up.
CHEVYRCKS is offline   Reply With Quote
Old August 12th, 2009, 11:07 AM   #16
Biggreen89
mr. yoder
Biggreen89's Avatar
i was told with this tcase i have if i put lockouts on the axles then it will be like a normal 4x4 but the driveshaft will still spin also can i run an inline fuel pump with the tbi
Old August 12th, 2009, 11:09 AM   #17
boggin-machine
is that what your dad told you. you couldnt be more wrong about that
Old August 12th, 2009, 06:28 PM   #18
Biggreen89
mr. yoder
Biggreen89's Avatar
dose anyone know if i put the lockouts on my dana 44 it will be like a normal 4x4 insted of all time 4wheel
Old August 12th, 2009, 06:30 PM   #19
Rebel2345
Rebel2345's Avatar
Yep, if you put locking hubs on your axle it will allow the front tires to freewheel.
Old August 13th, 2009, 01:28 PM   #20
Biggreen89
mr. yoder
Biggreen89's Avatar
thanks for the info also with the tbi can i run an inline fuel pump i was told that inline pumps dont push enough psi for tbi
Page generated in 0.34671 seconds with 84 queries
