!!Need Mechanic in Canton Area!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2009, 01:18 PM   #1
AGoodBuzz
Default !!Need Mechanic in Canton Area!!
Screw it. I have too much on my plate to mess with this. I need a competent mechanic in the Canton area.
I changed my D44 front diff axle seals (yes, I pulled the carrier out and everything) and when I put it back together the Front Lock light keeps blinking, even with the key out of the ignition. I opened the case back up and checked the locker for binding, etc. and it seems fine, but who the F* knows what else could be wrong, and I'm way too busy to mess with it any more. I am reluctantly admitting that I need help.
It's a 2004 Rubicon. I need a competent diff/air locker mechanic. Preferably someone with references from this site. If I don't hear anything by Monday night I'm having it towed to the dealer.
Please call: (734) 560-7226 - Dennis
Of course, I pay cash. I should have all the tools you need.
~D~
AGoodBuzz is offline   Reply With Quote
Old August 9th, 2009, 03:14 PM   #2
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
the first thing i would do is see if there is any codes. body control module, 4x4 module?
i think my scanner can do this.
Old August 9th, 2009, 06:28 PM   #3
AGoodBuzz
Thanks for the response. I have an OBD I&II computer, and can check that, but I believe it is probably a mechanical issue. There was no problem until I pulled the whole carrier and locker assembly out to change the seals, and after I put it back in the problem started.
If I can pay someone who knows to come check it out, I'd have the covers off, axles pulled, beer cold, and everything ready to go. Otherwise I ship it to the dealer. This seems more critical than most repairs that I would normally do.
Old August 9th, 2009, 08:50 PM   #4
04 EDGE
04 EDGE's Avatar
well if you can access the proper module with your scanner you should be able to retrieve codes as to why the light is flashing. that will point you in the right direction.
Old August 9th, 2009, 09:07 PM   #5
Mr Toes - R.I.P.
November 7, 1958 - July 22, 2011
Mr Toes - R.I.P.'s Avatar
~D~
Cash For Clunkers, go to the Toyota dealer on Mi ave they'll give you 4500 for it....LOL
Mr Toes - R.I.P. is offline   Reply With Quote
Old August 10th, 2009, 06:24 AM   #6
AGoodBuzz
That's about how I feel right now too. Pulled the carrier out twice and looked it over and put it back in and same f*ing problem...
I need someone to show me once. I can have it all pulled apart and ready. I pay CA$H!
Page generated in 0.21551 seconds with 40 queries
