trans fluid help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2009, 10:51 AM   #1
trogdor48430
trogdor48430's Avatar
Default trans fluid help
my truck takes dextron and i have 5 qts reg ATF in it. sould i drain it all and start fresh or will it be ok cause i dont wanta kill my trany thanks
trogdor48430 is offline   Reply With Quote
Old August 9th, 2009, 01:54 PM   #2
Yota Bill
regular ATF is Dexron III/Mercon, so I dont really understand your question...if your trans calls for Dexron, Dexron III, then you already put in the right oil...if your trans calls for Dexron VI, then yes, you need to drain out what you put in and add the right stuff
if all else fails, read the label on the oil bottle, it actually says stuff about the oil there
Old August 9th, 2009, 02:08 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
Originally Posted by Yota Bill View Post
If all else fails, read the label on the oil bottle, it actually says stuff about the oil there
You lie!
Old August 9th, 2009, 06:16 PM   #4
trogdor48430
it said not to use if u need dexron or mercon on the back, it said multi purpose atf on the bottle had all i had to get it off the trail. just seeing if it would be ok or not
Old August 10th, 2009, 12:18 AM   #5
Yota Bill
Originally Posted by Nuggets View Post
You lie!
that all depends on what she looks like and how gullible she is....
not sure what kind of oil you had, but if it said on the bottle that it is not compatible to DexronIII or Mercon, I would toss it
Page generated in 0.22352 seconds with 38 queries
