Rotors for Tow Rig - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2009, 12:22 PM   #1
XXXJ
Desert Rat
XXXJ's Avatar
Default Rotors for Tow Rig
Cross drilled? gas and heat dispersion
Slotted? heat dispersion variable surface area.
Grooved? : variable surface area
Factory OEM dealer part? Heavy, heavy, heavy, heat conduction dispersion.
Replaced my brake rotors from cross drilled because of the cracking.
What are your thoughts and experiences.
XXXJ is online now   Reply With Quote
Old August 8th, 2009, 01:14 PM   #2
Kawierider
Kawierider's Avatar
My opinion that you have two choices.
1. factory. heavy, yes, but large mass heats up less quicly. Less prone to warping.
2. aftermarket rotors. I'm not a big fan or slotted or cross-drilled rotors. It reduces surface area for the brake pad, and I have to imagine that it increases brake pad wear. If i was going to buy an aftermarket rotor a finned rotor would probably be your best bet. IMHO
Old August 8th, 2009, 01:22 PM   #3
XXXJ
Desert Rat
XXXJ's Avatar
Additional note: I've been using the EBC green pads with good success.
Page generated in 0.12438 seconds with 32 queries
